Old 08-11-2020, 05:40 PM
Enoch Enoch is offline
Banned
Untouched survivor break and fuel line clips. 3 of them are 3/16, 2 of them are 3/8 and 2 of them are 5/16. $15 each. PPFF
Old 08-11-2020, 05:45 PM
Banned
Original unrestored TCS solenoid to intake manifold mounting stud and nut. Stud still retains all of its original black phosphate plating as does the nut. Both of them have original orange overspray on them. You won't find nicer original pieces. $35 PPFF
Old 08-11-2020, 05:48 PM
Banned
Original 67 on up trunk to trunk hinge mounting bolts with bright blue paint on them. Can't tell if it's Marina Blue or Lemans Blue. Excellent for that car that is missing bolts with original paint. RBW head marking.$30. PPFF
Old 08-11-2020, 05:50 PM
Banned
Original restored throttle cable to accelerator stud clip with S stamping and dimple.$15. PPFF
Old 08-11-2020, 05:53 PM
Banned
Excellent original restored 63 through 67 Corvette MB stamped courtesy light door jam switches.$40. PPFF ************SOLD************
Old 08-11-2020, 05:58 PM
Banned
63 through 67 Corvette front headlight support rod mounting hardware. Included are 2 RSC grade 2 bolts that mount the rods to the headlight and support brackets and 2 dog bone head marking bolts that attach the rods to the radiator support. Also included are two Phillips head screws with lock washers and flat washers that attach the L brackets to the lower valance. $40. PPFF
Old 08-11-2020, 06:01 PM
Banned
63 through 76 Corvette gas door to body bezel mounting screws and P stamped u- nuts. Excellent original pieces.$35. PPFF
Old 08-11-2020, 06:04 PM
Banned
Excellent original restored 63 through 67 Corvette power brake booster to fire wall mounting bolts. Grade 2 anchor head marking.$30. PPFF
Old 08-11-2020, 06:08 PM
Banned
63 through 67 Corvette restored radiator support to front frame horn mounting bolts; RBW head marking with waffle stamping. Included are extra thick square edge lock washers and thick over size flat washers; all restored original pieces. Excellent condition.$40. PPFF
Old 08-14-2020, 05:06 PM
Banned
Original assembly line installed white stripe vacuum/smog hose. 13-1/4" long. $15 PPFF
The Following User Says Thank You to Enoch For This Useful Post:
HuggerSS (08-14-2020)
