Old 02-19-2020, 02:02 AM
67since67's Avatar
Originally Posted by 67 Nova Boy View Post
If you look at the rim on a "DA" Chevy ll you can see the bulge the rim has to clear the caliper. the DG does not have that on a chevy ll.
Dave
67 Nova Boy
Yes indeed, I just sat a DA and a DG side by side and the "bulge" is very clear, and I now know why it's there. I am happy to have learned something today! Thanks Dave!!
Bill W
Old 02-19-2020, 02:36 PM
L72Biscayne L72Biscayne is offline
Bill, Do you know what color the DG wheels are
on the outside and inside? Does the color differ if you have the mag wheel covers in relation to trim rings and center caps? Thanks, Dave.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
Old 02-19-2020, 06:22 PM
67since67's Avatar
Assembly line installed '67 Chevelle DG wheels were a shade of satin black on the back side, with the exception of some or all Fremont (CA) installed DGs were grey. All DGs were true argent silver on the front side, and were exclusively part of the J52 disc brake option and only trimmed with trim rings and center caps like attached pic.
Also, Chevelle DG trim rings are not the same as Camaro DG rings.
Drum brake cars used a std. steel wheel along with wheel covers or caps. (A whole 'nother subject!)
Bill W
L72Biscayne (02-19-2020)
  #14
Old 02-19-2020, 08:36 PM
Bill, My car is a Fremont car so I think I'll paint the inside gray and the outside satin Black for the Mag type covers. Thanks Again.
Old 02-19-2020, 08:47 PM
67 Nova Boy's Avatar
Bill W
So, they used a 7"trim ring on a Chevelle (closed hole for valve stem) and a 6" for the Camaro? (Open hole)
Dave
67 Nova boy
