Old 01-07-2020, 03:57 PM
Motorhead848 Motorhead848 is offline
Thanks guys for the input. I’ve known about the car for a little bit and the owner is finally ready to let it go. Unfortunate about the motor. It was a big let down for me. But given a 70 I figured it’s still worth checking out if it could be had for the right price. I was figuring on a sub 10k depending on what parts are still present and what options. As well as documents. If no tank sheet, I feel it’s probably just a parts car at that point.
Thanks again SYC
Mark
Old 01-07-2020, 04:57 PM
MosportGreen66's Avatar
Thanks again SYC
Mark
SMOG system, carb, intake, alternator, and even the starter are fairly expensive items... the more it has, the more you can feel comfortable.
Old 01-07-2020, 05:32 PM
purple panther purple panther is offline
a 70 LT-1 is a lot different than a detuned 71 lt-1
Old 01-07-2020, 10:10 PM
L72Biscayne L72Biscayne is offline
This past summer I looked at a 70 Lt-1 Coupe Matching numbers right in my home town. Donnybrook green saddle leather . Long term owner 30 plus years. No smog, alternator was wrong and the carburetor wasn’t correct. TI harness was still there but the wrong distributor. Lacquer repaint back in the 80’s. Driver quality. He was asking around 30K. I passed on it because I’ve restored one before and I now how rare and costly these parts are.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
Old 01-07-2020, 11:10 PM
SMS's Avatar
SMS SMS is offline
My 70 was a monster. On BFG radials with 4.11 gears and headers thru the mufflers it ran 12.30s.
Here is my old car in an ad I found online being sold again.
http://davidsclassiccars.com/chevrol...ocumented.html
The Following 4 Users Say Thank You to SMS For This Useful Post:
markinnaples (01-08-2020), PeteLeathersac (01-09-2020), purple panther (01-08-2020), ZiggyL78 (01-16-2020)
  #16
Old 01-09-2020, 04:39 AM
Update- car was definitely an LT1. Silver t top with black dlx leather interior, tilt, windows, Pwr brakes, and alarm. Unhit body for the most part, small repair to the hood surround and the exhaust panel was molded in and repainted. As far as original parts, intake and dated correct heads present, valve covers, pulleys, TI module, 3/5 wheels, M21, HD rear end, air cleaner and fan. Looked for a tank sheet but no dice. Inspection camera was broken when I got there. Made him what I thought was a fair offer. So we will see... need it like a hole in the head but it’s about 3 miles from my house.
Thanks again for the help!
The Following User Says Thank You to Motorhead848 For This Useful Post:
seventieshow (01-09-2020)
  #17
Old 01-09-2020, 11:44 AM
seventieshow seventieshow is offline
"intake and dated correct heads present, valve covers, pulleys, TI module"
If it's dry it sounds like a great car. Not that difficult to find a 3970010 4 bolt block, although the casting date can be a challenge. Tank probably swapped in the past due to to rust.
Old 01-09-2020, 08:13 PM
EZ Nova EZ Nova is offline
So, let me get this right?
1970 Corvette LT1 350/370Hp car. STOCK but for headers, with 4 gear and 4.10's on a BFG Radial TA, you were going 12.30's? That to me is pretty impressive to me.
Often wondered about doing a mild stoked to 383 LT1 with some head work, intake and cam. Put it in a '66 Nova L79 clone. thing would be a fun little car for sure.
BUT not a SB guy, BUT emm?????
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Old 01-09-2020, 08:17 PM
SMS's Avatar
SMS SMS is offline
Stock heads were worked and milled (a lot) and it was .030 over but otherwise pretty much as factory. Block was from 1974.
Old 01-09-2020, 08:18 PM
SMS's Avatar
SMS SMS is offline
Good luck! We all swear off projects..... Until one comes along.
