Old 02-08-2020, 06:14 PM
Enoch Enoch is offline
Banned
67 - 69 Camaro and Firebird emergency brake mounting hardware.
Set 1 has an E head marking bolt and nuts. 2 sets available.
Set 2 has RBW headmarking bolt and nuts.
$35 per set.
*****ALL SOLD*****
Old 02-24-2020, 09:05 PM
Banned
Excellent original restored antenna cable to rocker pinch Weld retaining clip. Very very nice and not being reproduced. $25. PPFF **********SOLD**********
Old 02-24-2020, 10:16 PM
Banned
Perfect restored single Pole MB stamped courtesy light switch for a door jamb. Replayed it many years ago and sat on the shelf. $20 PPFF *******SOLD*******
Old 03-01-2020, 10:03 PM
Banned
Original power window wire harness retaining clip. This was used on C 2 corvettes and on other models to retain the harness underneath the dash. $30. PPFF (X)
Old 03-02-2020, 01:13 PM
firstgenaddict's Avatar
I found the clip is also used to retain the rear seat speaker wire in the pass side wire gutter.
Speculating that IF power window or rear defog runs down the pass side it would be used for their retention as well.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
The Following User Says Thank You to firstgenaddict For This Useful Post:
Enoch (03-03-2020)
  #16
Old 03-03-2020, 08:36 PM
Banned
I believe you are correct! As that's what I've seen.
Old 03-14-2020, 12:00 AM
Banned
Excellent restored XS stamped single terminal courtesy light switch.$20. PPFF
Old 03-17-2020, 09:00 PM
Banned
Excellent original unrestored assembly line installed Delco Remy dimmer switch, grommet and mounting bolts. You won't find a nicer original one. Works perfectly. $50. PPFF
************SOLD************
Old 03-19-2020, 09:30 PM
Banned
67 thru 70 bucket seat back release knobs and Allen set screws. Very nice original pieces.$25. PPFF (X2)
Old 03-19-2020, 09:38 PM
Banned
Original tung sol 552 dash 12 Volt flasher dated 2 2 9 (February of 69) $20. PPFF (X2) ************SOLD*************
