Old 08-27-2019, 06:08 PM
Hrlyfxdl's Avatar
Hrlyfxdl Hrlyfxdl is offline
Default Got a set
Originally Posted by Enoch View Post
Mid 1966 up small block with steel valve covers. Correct for l79 67 68 Z28 etc etc. Very nice original n a t head marking. $50 ppff (x)
Rich, I got a set of these from you awhile ago, they looked great. Thanks
The Following User Says Thank You to Hrlyfxdl For This Useful Post:
Enoch (08-27-2019)
  #12
Old 08-27-2019, 06:18 PM
Enoch Enoch is offline
Banned
Removed from a low mileage 69 Camaro. Power steering pitman arm part number 3953219. 1 1/8 inch spline hole. $60 ppff. Very nice restored original pit free piece. Very tight ball socket
5 and 1/4 inch Center to Center not fast ratio. Standard ratio.
Old 08-27-2019, 07:34 PM
Banned
Very nice original 12in long power break booster hose. When I took the check valve off it still had remnants of the paper tag. Still flexible. Has a couple of minor hairline cracks in the outer rubber. Still holds vacuum checked it before. $80.
Old 08-27-2019, 07:43 PM
Banned
67 68 69 Camaro Firebird under dash insulation. Original. I remove this from a 69 Z28 about thirty some odd years ago. It's been sitting in a box in the Attic since then. It has a couple of small tears here in there but it is the best original one I've ever taken out. The repos aren't even close. $350 PP FF
Old 08-27-2019, 08:09 PM
Banned
Original SB head marking grade 8 flywheel to crankshaft mounting bolts. Restored. $30 ppff
Old 08-29-2019, 03:39 PM
Banned
69 Z28 70 LT1 aluminum valve cover grommets. Extremely hard to find nice original ones like these. The one side is flat the other side is angled. All have their correct embossings and markings on them. $40 PPPFF
Old 08-29-2019, 04:34 PM
Banned
68-71 small block engine lift hooks. Absolute perfect condition. As nice as your going to find unrestored. The front hook has some original paint on it and the Omega stamp. The rear bracket doesn't have a stamping but has all the striation marks in the ridge is on the edge that only originals have. Both bolts have CP for their head marking the front is flanged and the rear is trimmed. $35 ppff (x)
Old 08-30-2019, 02:31 PM
Banned
Original big block short fuel pump mounting bolts, B&H head marking and L in a circle stamped fuel pump push rod plug. Very nice restored original pieces. $45 PP FF (X)
Old 08-30-2019, 07:34 PM
Banned
Excellent original restored small block fuel pump mounting bolts and fuel pump plate to block mounting bolts.
These are the 9/16 hex design fuel pump mounting bolts with the flying f head marking and the fuel pump mounting plate bolts have SEMS for their head marking.
I've included a picture to show why the mounting plate bolts are unique to this application and most people have the wrong ones. The fuel pump mounting plate bolts are a little bit longer than regular timing chain cover and small block oil pan side rail bolts. And that's to make up the difference for the thickness of the plate itself that they're mounting.
$45 for the set. Two sets available.
Old 09-01-2019, 04:25 PM
Banned
Convertible hinge mounting bolts with serrated bushings and lock nuts. Nice original pieces removed from a 69 pace car decades ago. Replated. $25
