Old 05-19-2019, 10:19 PM
Enoch Enoch is offline
Banned
Original 3/8 inch alligator skin fuel line with molding lines and ribs running the length of it. 14 inches long plus two original square Tang olive drab green clamps. $60
************SOLD************
Old 05-19-2019, 10:50 PM
Banned
Extremely nice 5 rib 1/8" black vacuum line. This was used for the smog pump AIR system along with the carburetor vacuum advanced lines also for the choke take off excetera excetera. 2 10" pieces and one clear translucent 1/8" vacuum T. $30.
Old 05-19-2019, 10:55 PM
Banned
Very nice very unique 11" piece of 1/8" vacuum line that is ribbed around the entire circumference. $15
Old 05-19-2019, 10:59 PM
Banned
Same vacuum line is previous post 1/8" ribbed around the entire circumference. This piece is 29" long. $30
************SOLD************(
Old 05-19-2019, 11:06 PM
Banned
32" piece of 8 rib 1/8" black vacuum line. Very nice condition. I've saved these houses for decades in boxes on shelves. $25
Old 05-20-2019, 01:44 AM
Banned
68-69 Rally Sport black vacuum hose. This is the hose from the port on the intake to the filter and check valve and to the vacuum tank that mounts on the wheel well. 76" with 12 ribs.very nice pice that is in excellent condition.. $35
Old 05-22-2019, 10:20 PM
Banned
My last one until I go out and find some more. Extremely nice alligator skin high performance small block water pump bypass hose. Extremely nice very flexible and pliable no cracks. On the one end of very little corner was tucked in when it was clamped but it will still seal perfectly as you can see the side screw clamp Impressions above it. $40
Old 05-23-2019, 09:32 PM
Banned
68 69 Rally Sport Camaro vacuum actuator relay hoses and T. Very nice original pieces removed from a pace car about 30 years ago. The small hose has three ribs and a very thin yellow line while the longer hose has a double yellow line with about six or seven ribs. Also included is the original Style quarter inch 2 3/16 inch vacuum tee. $25
Old 06-03-2019, 06:38 PM
Banned
Very nice original GM alligator skin small block open element air cleaner breather hose and elbow. I have these pieces sitting on a shelf for well over 25 years. $45
Old 06-03-2019, 10:28 PM
Banned
Original alligator skin air cleaner breather elbow hose with GM stamping. Also has three ribs on one side. $30
