Old 03-30-2019, 06:35 AM
mssl72's Avatar
mssl72 mssl72 is offline
I had that happen too once. Luckily I was driving on my way home. It seemed like more and more play was in the steering after making a turn. I pulled into the garage, shut it off and popped the hood. I saw basically the same thing you had pictured. I promptly replaced it. Lucky for you, you were home when you noticed. I couldn't imagine losing steering while driving.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 03-30-2019, 01:20 PM
Originally Posted by Stihl View Post
Wow! You are blessed. There was no unusual feel prior to failing?
Nope no warning at all
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 03-30-2019, 01:29 PM
XXXGoldL34M20's Avatar
do you have manual or power steering?
if you have manual steering that rag joint should be a 7 row dotted thread showing, I count only 5 which I think is for power steering.
The Following User Says Thank You to XXXGoldL34M20 For This Useful Post:
Charley Lillard (03-30-2019)
  #14
Old 03-30-2019, 01:34 PM
Originally Posted by 70post View Post
There are notches in the belled-out end of the intermediate shaft that should "catch" the two big rivets that are part of the rag joint. Still.....you don't want to have to rely on that if you have a questionable old rag joint.
Quite frankly, I would get rid of that poly disc.....it has no fiber or steel reinforcement in it from what I've seen...just a piece of polyurethane.
Also - at some point, GM added a stamped metal "cross brace" piece to the assembly (my '70 cars have the brace). It goes on under the two bolts. Better than no brace but it's still stressing both bolt locations of the rag joint material. Can't tell exactly from your pic but I swear I see the steel brace that I mention and it looks torn in two.
I deal with alot of these and have noticed slight stress cracks starting in the steel braces in a specific location. I can post pics if need be.
I noticed on the rag joint for the fast ratio steering (my car is standard steering) the stamped steel cross brace was present but not on the standard? The rag joint that came out of the car did not have the brace.
Yea the rivets should had caught but I suppose since I was turning the wheels from lock to center I had a lot of stress on the joint and the rivets just "popped" out of the flange? I do have 245 60's on the front of the car which is not easy to turn when parked.
After putting on the new rag joint the steering does feel less "loose" but it did not seem like it was so loose that it would fail.
Thanks for the well wishes too!
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 03-30-2019, 01:59 PM
EZ Nova EZ Nova is offline
Of my 3 older cars, only my 69 Nova has a rag joint. Both my 66 and 67 do not have rag joints with rack and pinion streering.
Why is a rag joint used from the factory instead of a u joint like my 2 cars have??
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Old 03-30-2019, 02:27 PM
Wow....was that a wake up call. Damn glad you were not injured.
I will be honest, I never gave those rag joints any respect other than dampening the vibrations coming up through the steering column. That has changed now!
Maybe we all should inspect our rag joints and replace them if needed. It would be sad to loose somebody over something as simple as that.
Paul
Old 03-30-2019, 04:11 PM
They weren't always dotted..I count 7 layers on your broken rag shown,which is correct for your manual steering.
4 layers came on power steering.
Old 03-30-2019, 04:41 PM
jdv69z's Avatar
jdv69z jdv69z is offline
Just replaced the rag joint on my 69 Z with power steering. Also had the steering gear box rebuilt. Half the splines on my rag joint were worn smooth. If you are running a 50 year old rag joint, I'd suggest that it may be time to consider a replacement. There also was an article I read by a retired Saginaw steering gear engineer with a lot of technical and do's and don't info. Definitely worth reading. Either Camaros.org or Team Camaro.
Jimmy V.
Old 03-30-2019, 04:58 PM
Ryan1969Chevelle's Avatar
Danny, I need to stop by and pick up that rebuild kit and rag joint. (Maybe one. Ight this week....
Ryan W31
Old 03-30-2019, 05:10 PM
Ryan W31
Sure Buddy,
Come on over, we'll have a beer.
