1. Mint 67-69 Camaro Nova LH & RH Lower NOS Control Arms.....Sold
2. 621 Aluminum Bell with Assembly Line Inspection Cover.....Sold 3. January 69 AM Radio $275.00 4. 733 Dated A 12 9, 11 inch Flywheel that is in excellent shape $175.00 5. Original 4spd application flat bottom Cowl Induction Air Cleaner $1500.00.....Sold 6. 1969 Camaro Z28 Yenko YH Rim Dated Feb 26, 1969 (Set of Four)......Sold 7. 67 68 Camaro Z28 or SS 4K L78 Rear Clutch and Fan.........Sold 8. 1969 Camaro Rally Sport Very Rare GM New Old Stock Actuator Shields ( LH and RH) NOS Actuator Shields $750.00 9. Mint 69 Z28 Lower Crank Pulley $350.00 10. 67-69 Camaro Rear Short Seat $400.00 11. Pair of February 633 Front Disc Brake Calipers Dated 52nd Day $350.00.......Sold 12. (4) DF Rims with the Large Upside Down DF Stamp.........Sold 13. 418 Aluminum Finned Valve Cover without drippers (Pair) $650.00 14. Mint Full Original Endura Bracket Set (Four Pieces) $500.00 15. Brake Booster Tower Stand....... Sold 16. Nice used original black 69 dash cluster......Sold 17. A used set 14x7 Trim Rings with correct 4 clips $75.00 ea 18. 69 Z28 or 67 Corvette (3) sets of 15x7 Trim Rings with correct 4 outer clips $400.00 a set of (4) 19. 69 Camaro Black Door Jamb Windlace )_Nice no Clips) $350.00 20. 403 Aluminum Bellhousing for a 10 1/12 inch Flywheel $100.00 21. Original Hurst Shifter $350.00 22. 4 Spd two hole Reverse Lockout $350.00.......Sold 23. Original Three wire separator Clover leaf for Spark Plug wires $45ea. 24. 798 Muncie Tag M21 $125.00.......(Sold 1 and have 1 left) 25. 356 Muncie Tag M20 $100.00 26. 67 / 68 4 Spd Radiator OD and IF Tanks $200.00 (Dated "A" January) 27. Rare 69 Camaro Big Block Throttle Rod $400.00 28. (8) Used Original Battery Hold down Bracket $60.00 ea. 29. (4) Dill Original Valve Stem Caps $400.00 .........(Sold 1 set and have 1 set left) 30. (4) Schrader Valve Stem Caps $400.00 ...........(Sold 1 set and have 1 set left) 31. 67-69 Original Assembly Line Small Block Oil Pressure Brass Fitting $175.00 32. Original 69 Camaro Offset Yoke Driveshaft $350.00 33. Complete Set of NOS Subframe Bushings $475.00 (Sold 1 and have 1 left) 34. 403 Bellhousing $100.00 35. NOS 4Spd Trans Mount........Sold 36. 69 Z Vacuum Hose Smog Tee $75.00 37. 9204 Brake Booster Dated 120th Day $375.00.....Sold 38. Used 1967 Alternator Deep Groove Pulley #3829387-AI $125.00 39. Original Mint 856 Smog Pulley...........Sold 40. Original Mint 1105 Power Steering Pulley......Sold Shipping is buyer's responsibility Many other Rare Camaro Parts and NOS Stuff to follow
67 Z/28 Butternut Yellow 69 Z/28 Rally Green 69 Z11 Pace Car (2) 69 RS/Z28 Lemans Blue / Olympic Gold 2010 2SS RS Aqua Blue 68 Z/28 Lemans Blue 2019 Corvette Grand Sport 68 SS Lemans Blue 69 RS/Z28 Maroon JL8 66 Corvette Ermine White L75 Last edited by luv2sixty9; 12-15-2019 at 12:55 AM. Reason: Adding info |
| Tags |
| 302 dz mo z28 yenko copo |
