Old 11-29-2018, 02:08 AM
marxjunk marxjunk is offline
id try to do it right too..theres a CRV motor for sale in Washington Mo..no vin..and i forgot the date code...but could find out
Mark
Old 11-29-2018, 12:09 PM
L72Biscayne L72Biscayne is offline
Being that you have the Built Sheet I personally would find a CE block dated 1971 or 72 then find a 1970 M22 trans assuming it's a four speed and build it as the LS6 that it is. Having the docs still makes the car worthy of being as correct as possible. There's plenty of Documented cars with CE motors.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
The Following User Says Thank You to L72Biscayne For This Useful Post:
Arrowsmith (11-30-2018)
  #13
Old 11-29-2018, 01:12 PM
John's Avatar
John John is offline
… What month was you LS6 Chevelle built ?
Old 11-29-2018, 01:13 PM
This.
  #15
Old 11-29-2018, 02:04 PM
Sean Sean is offline
Default chevelle
March of 70
I do have some parts, heads,manifold, carb, distributor, water pump, pulleys
70 LS 6 4 SPEED CHEVELLE
69 SS 396/375 HP 4 SPEED CHEVELLE
68 SS 396 CHEVELLE SS 396/375 4 SPEED
69 COPO CHEVELLE 4 SPEED #S MATCH
69 COPO CAMARO #S MATCH SURVIVOR (BLACK)
69 COPO CAMARO (BLACK)
55 GASSER L88 4 SPEED
66 NOVA "UNDER CONSTRUCTION"
70 440 SIX PAK CHALLENGER SUPER STOCKER
2001 RVW/LDR TRANS AM 1020" BBC 8 SYSTEMS
Old 11-29-2018, 04:28 PM
AutumngoldL78 AutumngoldL78 is offline
Sean. I'm in the same boat as you with my 70 Chevelle L78. It is documented Buildsheet,POP,order sheet but does not the original motor or trans.What i plan on doing is making it look correct with the right looking parts.Some of the parts might not be date coded,but it will look correct.If you did it this why you could save yourself some money.
Old 11-29-2018, 06:11 PM
ban617 ban617 is offline
If it came with a 454 I would just put it back in & get it to a point that you can enjoy the work you have done on it & just look for a CE block or an original that’s date coded , but in the meantime have fun with it ..
Old 11-29-2018, 08:14 PM
tom406 tom406 is offline
I can't see too much restomodding of a build sheet LS6. However, I'm usually in the "what you can't see is fair game" side of upgrading. If it were me, I would find a 1970 Hi Perf block (no '75 truck blocks, etc) and a 1970 M22 case (Any 1970 dates, not too concerned about date coded to car, esp if its an early build and date correct parts are tougher). I would fill that block with the longest stroker crank practical and a modern roller cam grind and fill that M22 with an aftermarket wide ratio gearset. I would use a light-ish flywheel for quick revving and fill the 12 bolt with 3.31 gears if it has 4.10s. It should pull like a monster and be OK on the freeway, all while looking stock and having a "correct" 4 speed with everything lining up exactly the way it should. When its time to sell, there aren't many excuses to give. My $.02, good luck.
Old 11-29-2018, 09:54 PM
ssl78 ssl78 is offline
You already have a lot of the expensive parts you really should put it back together with correct short block
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 11-29-2018, 11:16 PM
Stefano Stefano is offline
Put an LS engine in it and drive the heck out of it. Actually don't cut and/or hurt it and do whatever puts the biggest grin on your face. At the end of the day it doesn't take much time to swap out an engine / trans.
