Old 07-19-2018, 03:19 AM
DarrenX33's Avatar
Originally Posted by L78steve View Post
If the distributor was run on a Sun machine and it tested good you can rule the Dist. out as being the problem, points included.
That is how Jerry does them, which is why I went with him. And I share your sentiment.
1969 Z28
1972 Corvette
Old 07-19-2018, 03:21 AM
DarrenX33's Avatar
Originally Posted by cook_dw View Post
Was it running fine before the distributor rebuild? Swap distributors would be the first thing I'd do if the previous statement was true. If it cleared up then I would send it back. But FWIW its more than likely the points. Local autoparts store used to have points/condenser kit where the condenser was made onto the point plate and they were great. Never had an issue with them. Blue Streak was the name but I wanna say it was owned by Standard Motor Ignition or Products..
It was running equally terrible. That is why I had the distributor rebuilt. The shaft and bushings were basically destroyed. I also have a box of vintage AC Delco points.
1969 Z28
1972 Corvette
Old 07-19-2018, 03:22 AM
DarrenX33's Avatar
Would the engine experience the same symptoms if either the lifter got stuck or a valve spring broke?
Problem is I have no, or very little spark on two. Not sure how those would factor in...
1969 Z28
1972 Corvette
Old 07-19-2018, 03:23 AM
DarrenX33's Avatar
Originally Posted by Postsedan View Post
This is what I use on all my cars. As Phil said, today's points are junk.
Your very first tow ride home and you will throw away them points.
https://www.lectriclimited.com/break...nversion-85309
I have the Crane ignition on standby. Didn't want to put it in but maybe I will try it. I was hoping the work Jerry did was good considering it was tested.
1969 Z28
1972 Corvette
Old 07-19-2018, 03:24 AM
DarrenX33's Avatar
Originally Posted by tunes View Post
Change the coil. This sounds like a friend's car last year that suddenly wouldn't run. It had a weak spark and would try to start. The culprit was the coil.
I do have another here, but it doesn't seem to help.
1969 Z28
1972 Corvette
Old 07-19-2018, 10:48 AM
69L78's Avatar
69L78 69L78 is offline
Originally Posted by Woj View Post
It seems like the coil is the only thing you have left to change. Maybe swap out the coil for a known good coil? One thing I have found in the past is that most point sets, even the later GM are junk. I was told to give Echlin points a try, I did and really do like the quality of their points. I bought these at NAPA.
Good luck and let us know what you find.
I have never had a problem with points my whole life. I also buy from NAPA and use the heavy duty or high perf points with the heavier spring so you do not get the points bounce at higher pm. These are Blue Streak DR2270XP - points & DR70X - condenser. The Echlin distributor cap with the copper contacts is RR165.
Old 07-19-2018, 01:16 PM
bbbentley's Avatar
I would hope and think the OP has hooked up a vacuum gauge and ruled out mechanical problems before narrowing it down to electrical? But good point to mention, should this not be the case? And, as a side note, mechanical lifters don’t “stick”. I guess I am assuming it is a 69 Z he is working on even though it was not stated. And, assuming a mechanical cam, as well.
FULL OWNER HISTORY
Old 07-20-2018, 12:32 AM
Tommy Tommy is offline
I would do a compression test and pull the valve cover. A stuck valve or hole burned in a valve will cause an engine to act this way. Also, by pulling the valve cover it is possible to find a broken rocker arm or a push rod has bent or come out of the bore (usually due to the rocker arm...
Tommy
Old 07-20-2018, 12:44 AM
I reread first post. No spark until 1500 rpm then it is still weak? If all parts including coil have been replaced I would just drop in another distributor and see what that does.
Tommy
Old 07-20-2018, 02:34 AM
427_Rat 427_Rat is offline
If one lobe on the distributor cam (for #2 cyl.) was wore down, might prevent spark at low RPM and allow a weak spark at higher RPM when points "bounce"...possibly? Just trying to think what would tie it to only #2 cyl. spark. You might check clearance of points on each distributor cam lobe or at least #2 cyl. and a couple others to see if any variation is apparent?
