Old 05-04-2018, 07:30 PM
RAII4speed RAII4speed is offline
Angry
Originally Posted by novadude View Post
My old '70 Nova did the exact same thing with the OEM tank and cap, and I never did figure out why. The tank had no apparent issues with venting, and it didn't cause any performance issues, or tank damage, so I just lived with the "whoosh".
As I stated earlier, the original tank did not do that but it also had a leak around the filler neck next to the tank, Maybe the leak did vent it better. I just took the car for a ride to get gas and it performed well and it did "Whoosh" when I opened the cap.
I don't hate the rich, And I don't pitty the poor
Old 05-05-2018, 02:30 AM
L78steve L78steve is offline
Your leak allowed the pressure to vent.
Old 05-05-2018, 11:09 AM
Your building pressure caused the leak.
Old 05-05-2018, 11:57 AM
Yes I agree, What to do to stop the pressure build up ?
Old 05-05-2018, 07:49 PM
Lee Stewart's Avatar
Originally Posted by RAII4speed View Post
My gas cap is vented. And the tanks look the same.
Have you had your gas cap tested to make sure it is working properly? I believe Jiffy Lube can do it.
Old 05-05-2018, 11:05 PM
tjs44 tjs44 is offline
FYI,I put a repo tank in my 69 bird.It would build pressure in my garage that faces west in the afternoon.If I opened the"vented"cap it would have a big woosh.I had my 366 NASCAR tunnel port engine in the car,tried to start it one day and it was locked up.Pulled all the plugs and cranked it over,shot fuel everywhere.It had built enough pressure to push the gas past the needle and seats in the factory holley.VERY lucky it did not fire and push a rod threw the unobtainable block.To be safe I drilled a very small hole in the center of the cap.The vent allows air to be pulled in but not out.My factory 350 auto non A/C tank had a vent in the neck.Wish I had just kept it in the car.Tom
