Old 12-21-2017, 11:49 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Agreed, that looks like a W
He says there is original paperwork and a P-O-P
I ain't nobody, dork.
Old 12-21-2017, 01:10 PM
Tarrytown SS427s Tarrytown SS427s is offline
The 2Q on the tag automatically means it has a close ratio. 2F is the console gauges. Also see the 7K tach. Neat car! I hope it stays as an original rather than be restored. Hopefully it has the correct radiator and breather, as those are very tough items to find. It certainly looks nice enough to preserve. If it has the born with engine and trans, I'd value it in the mid-high 30s, but we need more info.
Steve
68 Caprice Estate
68 Camaro SS396 4 speed
The Following User Says Thank You to Tarrytown SS427s For This Useful Post:
Tracker1 (12-22-2017)
  #13
Old 12-21-2017, 01:22 PM
The W is a group 1 option code. Tinted windshield
Steve
68 Caprice Estate
Old 12-21-2017, 01:54 PM
fsc66 fsc66 is offline
Default L72
Looks like the engine has the Idler arm and pulley. Can't tell if the 7K tach has a 6K red line.
However, If the car was born with an M21 and it looks that way then the car is an L72 car.
Paul
[email protected]
Old 12-21-2017, 04:29 PM
Tracker1's Avatar
Only trans pic I have
Old 12-21-2017, 05:09 PM
Tracker1's Avatar
POP pic
Old 12-21-2017, 05:13 PM
Tracker1's Avatar
car is also equipped with K66 ignition
Old 12-21-2017, 05:30 PM
novadude novadude is offline
What a cool car!
Old 12-21-2017, 05:59 PM
Default L72
Well, now that we see the POP it's quite obvious an L72 car, "ID" coded engine.
As far as the trans, the M20, M21 and M22 all use the same Maincase casting number, Sidecover casting number and Extension housing casting number.
to help identify here is some help:
http://www.5speeds.com/muncie/home/identification/
Paul
[email protected]
Old 12-21-2017, 10:01 PM
As I mentioned earlier in this thread, the 2Q on the cowl tag automatically makes the car a close ratio. A wide ratio would have 2L on the tag.
Steve
68 Caprice Estate
