Old 10-09-2017, 10:54 PM
Mr. Chevy's Avatar
Thanks Lynn,
Just a 2:73 rear gear. Not doing a complete engine rebuild.. Just want to gain a little extra power from a good cam..
Rich
Old 10-09-2017, 11:15 PM
Then the one I recommended would be your best bet.
If you don't want to go with a roller, contact Eric about a comparable flat tappet cam.
Unless you are planning a run at Bonneville, most "performance" cams would make your combo fall on its face from a dead stop.
Old 10-09-2017, 11:59 PM
Mr. Chevy's Avatar
Thanks again Lynn...
Rich
Old 10-10-2017, 03:34 AM
wrench wrench is offline
Default Cam selection
Originally Posted by KenMaisano View Post
A Comp 260 or 268 would be best for your application.
If they haven't changed the specs the Comp
Cam 268 would be a good choice. Installed a lot of Them back in the day.
Old 10-10-2017, 12:07 PM
Post My 2 cents..
2.73 rear and Powerglide tranny...that combo doesn't spell performance
Adding the 4 barrel and a fresh valve job won't hurt, but your performance dollars would be better spent on a little more gear [maybe 3.31/3.42]...and if possible a TH350 tranny...should bolt right in where the glide is now.
Those additions will add much more to the equation and enjoyment than a cam swap...once you have those items behind you, then consider other engine mods.
good luck..wilma
Old 10-10-2017, 01:59 PM
m22mike's Avatar
m22mike m22mike is offline
Best bag for you buck might be a 3:31/3:36 gear, and RPM wise it will be OK at 70 plus.
Mike
