Ad said it scored 997 out of 1,000. Maybe it was restored how gm built it. Fit and finish wasn't perfect in 1969 on some cars
BTW - you can say anything you want in an ad. Doesn't make it a fact. |
It is a beautiful car and I'm not usually one to pick apart someone's work but, that fender and grill is pretty sad. Look at the screws holding the top of the grill to the header panel. Seriously? Not even close.
-Dave Semper Fi! 69 Camaro SS396 L34 X66 |
Aren't those the headlight washers?
Yes... I was sent the trim tag and pad vin stamp as well as the vin tag. The tags are legit. The vin stamp seems reasonable at this point but I am not were I can compare to others. I will leave it to someone else to post the info as I was not given nor did I ask if I could post the pics. Last edited by cook_dw; 06-07-2017 at 04:07 PM. |
My bad... Looked like someone had used regular sheet metal screws. Bad assumption that I based on the rest of the pic.
Looks like more than one part isn't the correct shape. Repop parts? I noticed the car has a mix of interior.
Bill |
| The Following User Says Thank You to Billohio For This Useful Post: | ||
Spike (06-10-2017) | ||
For comparison sake. This car scored 995 and got the "Gold Spinner Award.."
https://www.mecum.com/lots/DA0914-19...-yenko-camaro/ |
Kurt have you seen the engine code on this pad? I still havent had a chance to compare but you obviously trump me anyways. Just curious. You can pm or email me if that is better.
| The Following User Says Thank You to cook_dw For This Useful Post: | ||
68 Chevy II (06-08-2017) | ||
