Old 05-22-2017, 10:30 PM
bbbentley's Avatar
Gavin-no such thing as a "small block" frame. There is a web site, camaros.org that will give you the education (without tuition) you need so that you may learn what will give you an accurate restoration.
(rear)crossmember- as in the piece that unbolts from the rear of the subframe and holds up the transmission.
Good luck
FULL OWNER HISTORY
Old 05-22-2017, 10:34 PM
Lee Stewart's Avatar
SB (Top) vs BB (Bottom) Cross Member 67-68 Camaro
Old 05-22-2017, 10:59 PM
L78Kiwi L78Kiwi is offline
Thanks again for your help. I will order a set of 67-68 frame and engine mounts and then progress through the other required parts.
From the advice I think I need to take a closer look at the oil pan. From what I can make out there should be no difference between a 427 L72 and a 396 L78 oil pan? Unless the oil pan has been modified......would anyone know of any common modification which would affect the clearance of the oil pan to the cross member?
Regards Gavin
Old 05-22-2017, 11:23 PM
AFAIK this is the oil pan you should be using - BB Camaro. Does yours look like this? Or does it look like the one below?
Old 05-23-2017, 12:53 AM
Thanks Lee, from what I can see the oil pan I have looks like the first image. But the drain plug on mine is at the back. I suspect it had been moved as when it was stripped it had been brazed in the new position
Old 05-23-2017, 01:32 AM
1967 396 Camaro SS with 4 speed
Old 05-23-2017, 01:52 AM
plum67 plum67 is offline
That's a small block cross member installed backwards
Old 05-23-2017, 03:25 AM
Is that right? Oops!
How about this one - supposed to be an L78 396 4 speed in a 1968 Camaro:
Old 05-23-2017, 03:39 AM
bigsixman bigsixman is offline
Second set of photos is mounted ok.
69 camaro X11, 56,000 miles, original HO paint
67 camaro SS/RS, Butternut yellow, bench, fold down
Old 05-23-2017, 09:55 AM
Hello here is some images. I think in comparison to the images posted the oil pan might be over sized?
