Old 05-11-2017, 03:37 PM
enio45 enio45 is offline
Thanks - yes great shape....thanks for the compliment
Sorry you missed them - and also thankful for Chris's purchase.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 05-11-2017, 07:10 PM
Is RPM only a rust inhibitor or did the RPM give the "GRAY" coloration to
the springs ?????
Is RPM expected to hold off RUST for a long period of time or would
you occassionally use FLUID FILM or BOESHIELD. LPS etc
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 05-11-2017, 07:17 PM
Slight amount of slip plate on the metal with rpm on top
Rpm is a protective paste coating. Reapplicaion is needed dependon
On ur application. For show car not driven much and az weather
It last a very long time
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 05-11-2017, 08:27 PM
Are you using (which exact product #) SLIP PLATE for its coloration properties
or also as a rust inhibitor ????
Aerosol or Paste (Brush or Wipe on ???)
Thanks for the education......
Chuck Sharin
[email protected]
Old 05-12-2017, 11:21 AM
iluv69s iluv69s is offline
great deal...beautiful springs !!
Old 05-12-2017, 02:10 PM
Chuck, for the coloration of the bare metal i use a small amount of slip plate and rub it into the surface and wipe it down good - gives a nice even look to the metal coloration
then i use the rpm as a paste and rub that in.....a good friend of mine looks to heat the parts up and allow the paste to work its way int the pros of the metal for a better protection...that does work nicely.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 05-12-2017, 08:06 PM
Eddie, Thanks for all your helpful education.....
I will run spring leafs thru large shot blasting machine my powder coater
has......and try your suggestions!!!!!!
Are you buying.using SLIP PLATE #???? as a AEROSOL or smallest size paste can ???
from which vendor source ????
Chuck Sharin
[email protected]
Old 05-12-2017, 11:16 PM
your welcome Chuck
aerosol can is what i buy i believe from graingers
a little on the products and wipe it in
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
