Old 05-02-2017, 11:15 AM
MosportGreen66's Avatar
https://www.amazon.com/Kleanstrip-GS...grease+remover
and if that doesn't work... try thinner!
Old 05-03-2017, 02:24 AM
Originally Posted by frankk View Post
So tell us more about the purple degresser
It is a all purpose cleaner/degreaser. We used to get it in 55 gallon drum. To use it as a cleaner you had to dilute it with 50 percent water, If you want to remove nasty grease or use as a floor cleaner you use it full strength. Castrol has something similar called Super Clean.
Mark
Kentucky Gold 70 SS/RS L78.
81 Z/28 Silver/Silver Int
09 G8/GXP #992
83 El Camino
Old 05-05-2017, 03:32 AM
Kurt S Kurt S is offline
I have a five gallon bucket of the same stuff called White Lightning. It will take your fingerprints off...
Kurt S - CRG
Old 05-05-2017, 11:55 AM
NorCam's Avatar
NorCam NorCam is offline
I've been using Citra Solv for a couple years now. Plant based cleaner & degreaser that will cut through almost anything. Still hard on hands when used straight up but also works well diluted with water. Smells great while using it and leaves your finger prints intact.
https://www.citrasolv.com/citra-solv-intro
Old 05-06-2017, 03:07 AM
I used a citrus cleaner the other day to remove some nasty tape residue - way exceeded my expectations!
Kurt S - CRG
