Old 12-28-2016, 03:34 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default Re: Valve Spring Compatibility
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78steve</div><div class="ubbcode-body">Gross is before loss. Total is what you end up with. If you have a clearance of .030 subtract that from gross. So at .625-.030=.595
Even with Hydraulic there will be some lift loss. </div></div>
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: EZ Nova</div><div class="ubbcode-body">I think you'll be fine. Or possibly take out the damper and get the rate down some too. I wouldn't second guess this with solid just not sure as I've never ran hyd cam stuff.
Dave BTW that cam only &quot;works&quot; to 6200 anyway. 2600-6200</div></div>
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 1971ls6</div><div class="ubbcode-body">Dave, the 1924 are the springs I gave in my motor, they are installed at 1.92</div></div>
Yes, those were the springs you hooked me up with. It ended up being a moot point. He ordered the Lunati set just to be sure. I'm going to still build that 408ci I have if I can get some reasonable machine work done to the heads. I'll install your springs in that motor when the time comes.
Sorry for the delay guys. I was sick through Christmas. Just getting back to all this now. Thanks for the help.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
