Old 12-16-2016, 02:52 PM
novadude novadude is offline
Default Re: Clutch recommendation
Something to consider about parts store clutches (Luk, etc) and high winding engines:
Centerforce tech dept told me the centerforce pressure plate has a ductile iron pressure ring (as did Hays). I believe some of the cheaper kits OEM replacement kits use a grey iron pressure ring, which has a higher chance of exiting the bellhousing in pieces when abused. I've never had any luck getting the OEM clutch people to answer any tech questions about the materials they use. You'll also find that many of the clutch companies use stamped covers from the same suppliers, as there are only one or two companies making the components than go into these clutches. All the "manufacturers" just source the components and build the assemblies to their own specs.
I suspect (don't know for sure) that the pressure ring material (ductile vs cast)is the difference between a $200 pressure plate and a $100 pressure plate.
Old 12-16-2016, 03:05 PM
Steve Shauger's Avatar
Administrator
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: novadude</div><div class="ubbcode-body">Something to consider about parts store clutches (Luk, etc) and high winding engines:
Centerforce tech dept told me the centerforce pressure plate has a ductile iron pressure ring (as did Hays). I believe some of the cheaper kits OEM replacement kits use a grey iron pressure ring, which has a higher chance of exiting the bellhousing in pieces when abused. I've never had any luck getting the OEM clutch people to answer any tech questions about the materials they use. You'll also find that many of the clutch companies use stamped covers from the same suppliers, as there are only one or two companies making the components than go into these clutches. All the &quot;manufacturers&quot; just source the components and build the assemblies to their own specs.
I suspect (don't know for sure) that the pressure ring material (ductile vs cast)is the difference between a $200 pressure plate and a $100 pressure plate.</div></div>
That may be so, but you would think the higher priced clutches would identify this safety feature. I suspect that may not be the case, but again if it's true that would be a great selling feature. Safety is a priority for all of us.
www.yenko.net
www.vintagecertification.com
Old 12-16-2016, 03:18 PM
Like I said - the stock clutches may even have ductile pressure rings, but when I tried calling the Sachs and Luk &quot;tech line&quot;, nobody could tell me. The performance clutch companies at least gave answers (right or wrong). Hays even calls out this feature in the description of their street/strip clutch line.
Old 12-16-2016, 03:17 PM
Unless you are drag racing/hard thrashing and trying to spin a pair of slicks there is really no need for a blow proof unit. A quality manufacturer will work fine for the street and an occasional hard launch and high RPM's with street tires.
We ran L88 set-ups (diaphram) back in the 60's-70's purchased across the counter at Chevy driving to school and occasional racing on the weekends.
Old 12-16-2016, 03:22 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">Unless you are drag racing/hard thrashing and trying to spin a pair of slicks there is really no need for a blow proof unit. A quality manufacturer will work fine for the street and an occasional hard launch and high RPM's with street tires.
We ran L88 set-ups (diaphram) back in the 60's-70's purchased across the counter at Chevy driving to school and occasional racing on the weekends. </div></div>
I am occasionally drag racing/hard thrashing and trying to spin a pair of slicks (drag radials). [img]<<GRAEMLIN_URL>>/wink.gif[/img] That's what these cars were made for, right?
I just feel better knowing that I don't have a junk cast flywheel etc tucked inside my lightweight OEM aluminum Bellhousing. Remember - ALL the stock stuff you buy at parts stores these days is all coming from overseas, and I don't have the confidence that it is made to the same standards as GM-designed cast flywheels in American factories. Just because the stock stuff worked in the 60s doesn't mean that the OEM replacement shopped to the lowest Chinese bidder will perform the same.
Old 12-17-2016, 02:48 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: novadude</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">Unless you are drag racing/hard thrashing and trying to spin a pair of slicks there is really no need for a blow proof unit. A quality manufacturer will work fine for the street and an occasional hard launch and high RPM's with street tires.
I just feel better knowing that I don't have a junk cast flywheel etc tucked inside my lightweight OEM aluminum Bellhousing. Remember - ALL the stock stuff you buy at parts stores these days is all coming from overseas, and I don't have the confidence that it is made to the same standards as GM-designed cast flywheels in American factories. Just because the stock stuff worked in the 60s doesn't mean that the OEM replacement shopped to the lowest Chinese bidder will perform the same.</div></div>
I don't think that black dual quad, E70 red line tired nova ever revved over 3 grand NovaBoy and that happened with a little dampness on the road surface. An aluminum cookie tray would work for your flywheel Buzz. YEAAA
Old 12-16-2016, 03:48 PM
scuncio's Avatar
scuncio scuncio is online now
I will say this...if you have survived a clutch explosion, you will always run a steel bell. I know I will....
Old 12-16-2016, 09:27 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
I like my feet... At the strip on slicks, I drop the clutch on the 5K chip... floored! Steel Bell with Block saver. SFI approved flywheel , Disc and PP.
Fun Times.
Gary
70 Chevelle SS-454 LS-5 M-22
Old 12-16-2016, 11:46 PM
67 Nova Boy's Avatar
I have a Center force and I hate it...In stock ready to go is a Vintage from the 70's 26 spline Schiefer Clutch/Pressure plate and a GM steel lite weight flywheel {16LB} for when the Muncie comes out for an Autogear M23Z.
I will never run a clutch without a Scattershield {Lakewood of course} and block plate. Had a friend that had one let go and it came right through the floor...cut the console in half and grazed his foot. This was in a Buick back in 1978 but I learned it matters to be safe. Parts in the old days were way better made {Stock} then the junk now a days. Don't ever settle, Have your parts checked before you put them in the car...send flywheels to the machine shop to check run out and surface condition when new.
Dave
67 Nova Boy
Old 12-17-2016, 06:36 AM
NorCam's Avatar
NorCam NorCam is offline
I have a McLeod 25lb SFI flywheel going into my 68 this winter along with an M22 Autogear and a Lakewood bell housing. I like my feet attached to my legs so I can shift, peddle the car and walk when I am done. [img]<<GRAEMLIN_URL>>/smile.gif[/img]
