Old 11-25-2016, 11:08 PM
Default Re: Your Cat D7 need a lift ?
Wherever I want !!!!
Old 11-25-2016, 11:22 PM
70 copo 70 copo is offline
Is this originally a GM built Sherman?
Old 11-25-2016, 11:45 PM
KM265S KM265S is offline
I bet you've got Ken (KWHIZZ) thinking that maybe he could use one of those for dropping in the LS motors in all the conversions he does.
Old 11-26-2016, 01:56 AM
Yours has the Sherman M4A3-E8 "Easy 8" suspension which would be 1945 vintage. I remember that from building military models back in my youth!
Old 11-26-2016, 05:28 AM
Weight: 46.8-tons (42,524-kg)
Length: 26' (7.95-m)
Width: 10' 1” (3.07-m)
Height: 11' 1” (3.37-m)
Crew: 4
Armor:
Hull front: .5” (13-mm)
Turret front: .5” (13-mm)
Weapons:
-Primary
1x .50-cal M2HB machine gun
-Secondary
1x .30-cal M1919A4 machine gun
-Ammunition
352x 40-mm
420x .45-cal
430x .30-cal carbine
Engine: Ford GAA V-8, 450-hp
Power/weight: 9.6-hp/ton
Fuel Capacity: 168-USG (635-l)
Range: 100-miles (160-km)
Speed: 21-mph (34-km/h)
The vehicle being offered, M74 Armored Recovery Vehicle (ARV), serial number 57895, was probably built by Bowden-McLauglin-York (BMY) between 1954 and 1955. It is unrestored and in original condition. It was last used by the West German Army and was part of the Budge Collection. It is still in its original German Army paint. The exterior needs to be cosmetically restored. The vehicle runs and drives well on an auxiliary fuel tank. The roadwheels, tracks and suspension components are good. All driver's controls and instruments are present and functioning. The interior needs cosmetic restoration.
Due to the increase in size of American tanks seen in the early 1950s such as the M26 Pershing and M46/47 Patton series, the U.S. military required a more powerful ARV than the Sherman based M32 series of ARV's. BMY developed a heavy-duty ARV using surplus M4A3 chassis. Designated the M74, the first vehicle was converted in July 1953 with full-scale production starting in February 1954. The conversion work continued until October 1955.
The M74 was built with a recovery winch that had a 90,000-lbs capacity, which was a 30,000-lb increase over the M32. It also added separate tow and lifting winches. To aid in recovery work, a bulldozer blade was added to the front of the hull. It could be lowered to act as an anchor during heavier recovery operations and could also be used as a light bulldozer. Unlike the M32, which used a windlass arrangement to raise and lower the A-frame, the M74's A-frame was hydraulically-operated. Integral stowage bins were added to the hull sides, which greatly increased stowage capacity and accessibility.
The M74 remained in U.S. service until the early 1960s when it was replaced by the M88 series of ARV’s, which were built using M48 Patton tank components.
Old 11-26-2016, 11:58 AM
Charley,
I am thinking that the tank had a new motor installed when converted in 1954 then?
Very nice piece either way.... I would think it started life as a late war tank built by GM which was later converted and got a Ford V-8 at that time.
More photos please... Preferably you in the drivers seat!
Old 11-26-2016, 12:22 PM
earntaz earntaz is offline
HEAVY METAL it is ...
Old 11-26-2016, 02:26 PM
Very impressive history lesson......I am impressed!
Are you the "Jerry M" for certifying WW II vehicles......you realize we will need one soon......lol. I see re-bodied tanks, re-pop trim tags and Chinese crap parts all in the future.....lol. Charley.....you have to protect us from these shananagins.
What do you charge for the service?
Paul
Old 11-26-2016, 03:18 PM
Engine is a 1100 cubic inch aluminum Ford V8.
http://www.fordgaaengine.com/
Old 11-26-2016, 03:22 PM
I actually found two rebuilt carbs for ours on Ebay. They were surplus pieces.
