Old 11-06-2016, 09:41 PM
ssl78 ssl78 is offline
Default Re: Camaro rearend decoding
Does it have multi leaf or mono leaf perches. I do not see the mount for the 67 traction bar
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 11-06-2016, 10:53 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Can you post a pic of the axle tubes going into the center section? BTW Im not a fan of the stamping but I could be wrong at this point..
Old 11-07-2016, 06:57 AM
Kurt S Kurt S is offline
Looks like a 67 axle. Should have monoleaf perches.
Is there evidence a radius rod bracket was attached? http://www.camaros.org/radiusrod.shtml
Kurt S - CRG
Old 11-07-2016, 01:02 PM
Fast67VelleN2O's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ssl78</div><div class="ubbcode-body">Does it have multi leaf or mono leaf perches. I do not see the mount for the 67 traction bar </div></div>
It's an October of 1966 rear end. 1967 did not have the traction bar at that point yet.
Day 2 is Life.
Old 11-07-2016, 01:15 PM
rafbody rafbody is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Fast67VelleN2O</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ssl78</div><div class="ubbcode-body">Does it have multi leaf or mono leaf perches. I do not see the mount for the 67 traction bar </div></div>
It's an October of 1966 rear end. 1967 did not have the traction bar at that point yet. </div></div>
If the stamped assembly date is correct it is a January 1967 assembled rear end and should have had the bracket for the rod.
Russ
Old 11-07-2016, 02:52 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: rafbody</div><div class="ubbcode-body">
If the stamped assembly date is correct it is a January 1967 assembled rear end and should have had the bracket for the rod. </div></div>
Were the perches and brackets added to the housing during assembly when the assembly was stamped? I would assume that wasn't the case.
Day 2 is Life.
Old 11-08-2016, 01:04 PM
Blownrsz Blownrsz is offline
It does not have the bracket for the traction bar. I'll get pics of the the spring mounts.
Old 11-08-2016, 02:22 PM
By that date, a 4.10 axle should have a bracket.
Kurt S - CRG
Old 11-09-2016, 12:15 AM
Here are the axle tubes and the spring mounts
Old 11-09-2016, 12:17 AM
After a lot closer inspection it looks like the traction bar bracket had been removed.
