Old 11-01-2016, 06:38 PM
Carleen's Avatar
Carleen Carleen is offline
Default Re: Can Am BBC
Front, Back. Top, Side.
Old 11-01-2016, 07:47 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Here is all the info that I have: casting #326711 Reynolds 68/69 Can Am block 4.44" bore with steel liners
Old 11-01-2016, 07:52 PM
Carleen's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69SSZL1</div><div class="ubbcode-body">Here is all the info that I have: casting #326711 Reynolds 68/69 Can Am block 4.44&quot; bore with steel liners </div></div>
Im sorry but thats my Block. not the last Picture.
I wanted to show what Pictures we need to see
Old 11-01-2016, 08:51 PM
PeteLeathersac's Avatar
Default Can Am BBC
Da' Grump used one or more Can-Am block(s)!
If any help, here's a few block casting #'s and related info I've posted here before.
Anyone please feel free to add missing/more info also clarify and/or correct any mistakes.
~ Pete
Can-Am blocks 68/69 - Reynolds
# 0-294550 = Linerless?
# 0-321270 = Linerless?
# O-326711 = 4.44&quot; bore with steel liners (427 ci)
Can-Am blocks 70/71 - Reynolds?
# O-399204 = 4.5&quot; bore and steel liners (509 ci)
# O-495102 = 4.5&quot; bore and no liners
ZL-1 Factory blocks - 1969 - Winters
# 3946052 (No 'O') 427 ci.
ZL-1 Factory blocks - 1997 &amp; up
# 3946053 (No 'O') 427 ci.
# 3992038 (O?) * may be 4.44&quot; bore w/ Liners - era?.
# ? - Yenko - Casting has YENKO
# ? - Yenko - Casting has Y E N K O
# ? - Yenko - Casting has Yenko Crest Logo
Note - The #3946502 quoted on Guinn's Engineering site is actually # 3946052 as shown in their pics.
Rex (09-24-2024)
  #15
Old 11-01-2016, 09:20 PM
Carleen's Avatar
I can update that list.
Can-Am blocks 68/69 - Winters
# 0-294550 = 4.250&quot; bore with steel liners (427 ci)
# 0-321270 = 4.440&quot; bore with steel liners no fuel pump boss (430, 465 ci)
# O-326711 = 4.440&quot; bore with steel liners (430, 465 ci)
# 3946052 = 4.440&quot; bore with steel liners (430, 465 ci)
# 3946053 = 4.440&quot; bore with steel liners (430, 465 ci)
# 3946053 427 ci
# 3946052 Yenko Casting LC 427
# 3946053 Yenko - Casting has YENKO
# 3946053 Yenko - Casting has Y E N K O
# 394605Y Yenko - Casting has Yenko Crest Logo
The Following User Says Thank You to Carleen For This Useful Post:
Rex (09-24-2024)
  #16
Old 11-01-2016, 11:31 PM
Carleen's Avatar
# 0-326711 = 4.440&quot; bore with steel liners (430, 465 ci)
Can-Am Block 70 Winters
# 3946052 = 4.440&quot; bore with steel liners (494 ci)
# 3946053 = 4.440&quot; bore with steel liners (494 ci)
# 3946052 427 ci.
# 3946053 427 ci
# 3946053 427 ci.
# 3992038 may be 4.44&quot; bore w/ Liners - era?.
Rex (09-24-2024)
  #17
Old 11-02-2016, 02:09 AM
I have internal engineering documents dated Feb 29, 1968 showing the following aluminum 427's equipped with sleeves:
19950-17-A (first development engine, installed in Corvette 78027 for F.I. development)
19950-17-J (Laguna Seca race and Riverside Practice, #3, #4, #6 resleeved and machined)
19950-17-K (ran LeMans for 14 hrs, approx 1000 miles, showed gasket burning on #1 cyl)
Not sure how these numbers correspond to the ones listed above, but I believe these were development blocks.
Mike
Old 11-02-2016, 02:27 AM
Hoovy88 Hoovy88 is offline
I will take some pictures tomorrow and post them. Guinn was convinced this was one of the early experimental blocks because of the crude casting and no numbers anywhere. Not quite sure what happened to him. Also, the fact that it was a dry sump block with the fuel pump boss and liners. Will post pics tomorrow!
Old 11-02-2016, 10:25 AM
Carleen's Avatar
# 0-294550 = 4.250&quot; bore with steel liners Experimental Prototype 67-68 Dry sump (427 ci)
# 0-321270 = 4.440&quot; bore with steel liners Experimental Prototype 68 no boss for mechanical fuel pump(430, 465 ci)
# 0-326711 = 4.440&quot; bore with steel liners Experimental Prototype 68 (430, 465 ci)
# 3946052 427 ci.
# 3946053 427 ci
# 3946053 427 ci.
Old 11-02-2016, 04:39 PM
here are some more...
