Old 10-28-2016, 09:23 PM
Default Re: Need to buy 69 z28 oil pan.
Just my opinion, but I believe the black one is worth $200, and assuming that is grease and not rust on the bottom of the assembly line pan, $550 for the pan and windage tray together. Another $50 if you have the studs.
Old 10-29-2016, 01:26 AM
Steve Shauger's Avatar
Administrator
The black/nos is not assembly line correct, although it will work fine as long as you use the correct thicker front seal.
NOS front radius 2.5 inches from peak of radius to top of pan (flip pan on flat surface to measure)
NOS has a center crease assembly line correct don't.
NOS has a second step on pan bottom.
Assembly line front radius measures 2 5/16 inches from peak of radius to top of pan (flip pan on flat surface to measure)
www.vintagecertification.com
Old 10-29-2016, 01:59 AM
I agree Steve. I think that is what we said, only without the dimensions.
Pan Comarison
Old 10-29-2016, 10:03 PM
Bead blasted, filled it with water and found a pinhole.
Old 10-30-2016, 06:30 PM
Bummer. Do you know the history on that one? Is it off a 68 maybe? I know the drain plug would be interchangeable, but I think the 69 had a 9/16 hex.
To the OP. I have a couple projects going today, but I believe I have at least one correct 69 pan. Don't know if I will get a chance to pull it out, clean it up and check it out today, but can if you are interested.
If you aren't concerned with it being assy line correct, Charlie's black painted pan will do the job fine, as Steve stated.
Old 10-30-2016, 09:08 PM
ds1 ds1 is offline
So the difference between a 68 and 69 pan is the drain plug?
1967 Camaro conv (first car)
1969 Camaro street car
1967 Super Stock SS/JA Joe Scott car
Old 10-31-2016, 03:23 AM
I am not sure Dan. I believe that is one difference. I have not compared 67, 68 and 69 side by side, so I can't say if there are other differences.
I remember locating a true 67 Z pan for a member here a few years back. Belonged to a friend who had put the 67 Z engine in his 57 race car (Z was wrecked) and kept the pan in his attic for years. I did not however, have possession of ito to make any comparisons to an original 69 pan or an original 68 pan.
Old 10-31-2016, 01:20 PM
camaro1 camaro1 is offline
http://www.ebay.com/itm/-/332018928364?
Here's one I just listed if interested.
front of pan center radius to pan rail measures 2.450 if that helps.
Thanks Rich [email protected]
Old 10-31-2016, 03:24 PM
Ebay oil pan
That's a fair price for an OTC pan.
Old 10-31-2016, 06:14 PM
sold!
Thanks Lynn, its rediculious what this gold impregnated junk costs and what some of these guys want for there extra special junk.
