Old 10-28-2016, 07:18 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default Re: 85 GMC wiper issue..
The simplest way to see if it's a ground issue is to run a separate ground. You could run a separate wire from a known good ground contact directly to the wiper case/ground wire. If when you turn the wipers on they aren't working, then you hook up the ground and they work, you'll know it's the ground. From there, you just find where the ground circuit has been broken. Broken wire, loose screw, rusted ground contact etc...
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 10-28-2016, 07:27 PM
thanks...almost too simple [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Old 10-28-2016, 08:08 PM
HawkX66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: WILMASBOYL78</div><div class="ubbcode-body">thanks...almost too simple [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img] </div></div>
That's what four years of Electronics in school gets you. [img]<<GRAEMLIN_URL>>/wink.gif[/img]
-Dave
Semper Fi!
Old 10-28-2016, 08:34 PM
The most technical electrical thing for me is using a 2 prong adapter on a 3 prong cord [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 10-28-2016, 08:44 PM
BTL BTL is offline
Not sure how to check it....but I would bet it is a bad ground inside the motor
