Old 10-12-2016, 03:05 PM
Default Re: F-41 rear sway bar 69 70 nova ss
Do you think that would bolt right in on a '71 Pontiac Ventura II?
I've got a friend who is restoring one and always looking for parts.
Old 10-12-2016, 03:34 PM
Zman1969 Zman1969 is offline
yes except for the upper mounts(not incl and hard to find) would need to be welded to body
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 10-13-2016, 12:30 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JRSully</div><div class="ubbcode-body">That is not a 70 bar set up. Originals had upright bar mounting flanges pointing down, not sideways. Believe that may be for a 71, 72 Nova or a Camaro. GLWS </div></div>
X2
Old 10-13-2016, 03:03 AM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
The bolt on mounts are used on 70 up Camaros/Firebirds and bolt to the underside of the subframe.
On 68-74 style Nova's and 67-69 Camaros the uprights bolt to the brackets which I provide a picture of (earlier post). The brackets are welded to the underside of the floor inside of the frame rails. The Gen 1 Camaros and 68-74 Novas use a narrower bar than the later (70 up) Camaros and (75 up) Novas.
I have a factory style rear bar on my 68 Acadian... I can measure the length on the weekend. Way too cluttered up there to get a picture of the bracket without lifting the car.
Best place to find these style bars (and brackets) are the X body 73-74 GTO's.
Gary
70 Chevelle SS-454 LS-5 M-22
Old 10-13-2016, 03:26 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78_Nova</div><div class="ubbcode-body">The bolt on mounts are used on 70 up Camaros/Firebirds and bolt to the underside of the subframe.
Gary </div></div>
FYI gen 1 camaro's dont have rear bars from the factory
75 and up Novas are same width as 68-74
90 Formula 350
Old 10-14-2016, 12:15 AM
nova7579's Avatar
nova7579 nova7579 is offline
The upper mounts in the pictures were only used on the Camaro. Since they have the part number label on them this was probably added after the fact and done the cheapest way possible. To add the rear sway bar on a 70-79 Nova you need the weld on upper support and the weld on upper mount to install like the factory did.
Brian
Old 10-14-2016, 01:04 AM
Donnie's Avatar
Donnie Donnie is offline
if I remember right. the upper mounts on my 70Z were welded on. I think the bolt on started sometime after 70
69 SS L78 Chevelle
70 SS 396 Chevelle
