Old 09-19-2016, 10:55 PM
camaromb camaromb is offline
Default Re: X22 COPO
Looks like N587056 is missing all the ZL2 wiring, missing the relay, no grommet/wiring to the switch in the hood, etc. Not the best example of a ZL2 equipped car.
I've never seen a factory ZL2 equipped car without the wiring hole pierced above the main wiring hardness hole in the firewall, including the 50 Jan. '69 built Yenko Camaros.
Old 09-19-2016, 10:49 PM
I must be blind. I can't read a thing.
Old 09-19-2016, 11:16 PM
Carleen's Avatar
Carleen Carleen is offline
I give up
Old 09-20-2016, 03:34 PM
Fast67VelleN2O's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Carleen</div><div class="ubbcode-body">I give up </div></div>
Don't give up. Just being objective. A COPO car is hard enough to prove as it is, and if it is a true real early COPO like you believe, you should stake your claim. I did see the M on the lower fender extension, but could not see the 427 markings. It could have been this for all we know. And honestly, the markings on the cowl weren't all that clear. If you cleaned it up and you can read it better, post up the photos.
Day 2 is Life.
Old 09-20-2016, 05:10 PM
Here are pics before and after spraying Boeshield on the crayon marking of the Blue RS ZL1. You might do something similar.
Old 09-20-2016, 08:17 PM
Carleen's Avatar
Old 09-20-2016, 07:16 PM
earntaz earntaz is offline
Aaah -- the secret is out ... in my USAF days we had Boeshield T-9 on benchstock. That stuff can be used for so many different things. I've used it to preserve alum moldings after stripping and repolishing them. I think it was originally used for preventing corrosion on alum surfaces. TAZ
Old 09-21-2016, 12:27 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Aaah -- the secret is out ... in my USAF days we had Boeshield T-9 on benchstock. That stuff can be used for so many different things. I've used it to preserve alum moldings after stripping and repolishing them. I think it was originally used for preventing corrosion on alum surfaces. TAZ </div></div>
where can you get this Boeshield?
Old 09-21-2016, 12:55 PM
SEARS carries it,so do certain tool stores around me.. http://www.sears.com/boeshield-t90004-t-...mp;gclsrc=aw.ds
Used to protect bare metal parts with very close tolerances like aileron controls that can't be painted.
Old 09-20-2016, 08:57 PM
PeteLeathersac's Avatar
Default X22 COPO
Sorry if I missed it but have you already sent/recv'd an NCRS Dealer shipped to report?
Just thinking it may be worth trying to track info from the other end?
Best of luck and like Matt said, don't give up!
~ Pete
