Old 08-29-2016, 10:13 PM
wundercluck wundercluck is offline
Default Re: 69 Camaro JL8 Rearend Value
Ya the last 4 digits of the part number are stamped on the outer hub- 7206
Don
Old 08-30-2016, 02:02 AM
lbnaz lbnaz is offline
Yenko Premier Member
Hello, update for today's hunt. I found the emergency brake cables, dust shields, rotors with E brake's, and the calipers. The things look like very low mileage. Still missing one axle and center section. There is a lot to go through. Any interest in purchasing call me. Thanks, Larry 520-349-2337.
Old 08-30-2016, 03:14 AM
Guest
Posts: n/a
Don how can you tell that from the pics posted?
Old 08-30-2016, 04:06 AM
On the axle shaft...the outer part where the wheel center fits around inside the lug nuts, if you look close it says 7206...
Old 08-30-2016, 10:53 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: lbnaz</div><div class="ubbcode-body">Hello, update for today's hunt. I found the emergency brake cables, dust shields, rotors with E brake's, and the calipers. The things look like very low mileage. Still missing one axle and center section. There is a lot to go through. Any interest in purchasing call me. Thanks, Larry 520-349-2337. </div></div>
I ain't nobody, dork.
Old 08-30-2016, 04:21 AM
3947206. ..JL8 axle part#
Old 08-30-2016, 04:45 PM
enio45 enio45 is offline
are the jl8 axles different that the stock drum axles??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-30-2016, 05:35 PM
Guest
Posts: n/a
I believe they are 13/16&quot; shorter
Old 08-30-2016, 05:54 PM
Guest
Posts: n/a
Thanks Don....looking closely at one of the pics I do see it.
Old 08-30-2016, 08:49 PM
From a reliable source JL8 axles are 29 11/16&quot; and the stock ones are 30 1/2&quot;. Frank is right. Haven't found the second one yet.
