Old 05-19-2016, 04:36 PM
RS_COPO_Canuck RS_COPO_Canuck is offline
Default Re: 70 Nova Bench Seat - Adjustment
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: YENKO DEUCE REGISTRY</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RS_COPO_Canuck</div><div class="ubbcode-body">Thanks - It just so happens to be a Deuce :^).
I guess I'll get a leg reduction </div></div>
Which one? </div></div>
114270W369585
Old 05-19-2016, 04:38 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DEUCE</div><div class="ubbcode-body">You guys must be very tall, I am 6'4&quot;, and I fit in with out much problems.
Mike </div></div>
I'm 6'. I wonder if there is something going on with the track. I need to have a close look at it.
A friend is the same size and has the same problem with his car.
Old 05-19-2016, 05:02 PM
WILMASBOYL78 WILMASBOYL78 is online now
I'm 6 ft. tall and drive quite a few bench seat Novas [img]<<GRAEMLIN_URL>>/wink.gif[/img] ...no problem here. Maybe the back/forth mechanism is hanging up and restricting full movement??
wilma
Old 05-19-2016, 05:07 PM
92646 92646 is offline
I installed a set of seat track extenders designed for a 1969 drivers bucket seat. I bought the pair of long brackets from Nitro Rat that sells on E-bay and the quality is first rate. The last time I had a bench seat car has been about 5 years ago but from what I remember I flipped the brackets upside down and I might of drilled two additional holes to make them work. These added 2 inches of leg room but it also raised the seat about a 1/2 of an inch.
Old 05-19-2016, 05:45 PM
CG - nice! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 05-19-2016, 06:21 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: WILMASBOYL78</div><div class="ubbcode-body">I'm 6 ft. tall and drive quite a few bench seat Novas [img]<<GRAEMLIN_URL>>/wink.gif[/img] ...no problem here. Maybe the back/forth mechanism is hanging up and restricting full movement??
wilma </div></div>
Thanks - I need to give it a thorough look to see if anything is going on with it.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: YENKO DEUCE REGISTRY</div><div class="ubbcode-body">CG - nice! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] </div></div>
Thank you :^)
Old 05-19-2016, 06:52 PM
Just to be clear I drilled the holes in the brackets to make them work everything else was left untouched.
Old 05-20-2016, 02:16 PM
Thanks all......If all else fails I will get a second set of rails and mod them....and keep the originals.
Old 05-23-2016, 04:31 PM
Zman1969 Zman1969 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 92646</div><div class="ubbcode-body">I installed a set of seat track extenders designed for a 1969 drivers bucket seat. I bought the pair of long brackets from Nitro Rat that sells on E-bay and the quality is first rate. The last time I had a bench seat car has been about 5 years ago but from what I remember I flipped the brackets upside down and I might of drilled two additional holes to make them work. These added 2 inches of leg room but it also raised the seat about a 1/2 of an inch. </div></div>
I was hoping this would work I'm 6'2&quot; and few times I tried to get in my bench seat 69 wasnt fun, maybe seat isnt all the way back doesent help that 2 doors have lower roofs than 4 door Nova's
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
