Go Back   The Supercar Registry > General Discussion > Mopar
Old 03-31-2016, 07:14 PM
RS_COPO_Canuck RS_COPO_Canuck is offline
Default Re: Dana 60 identifacation
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tracker1</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: A12pilot</div><div class="ubbcode-body">603109-2....70-72 and up B-Body, 3.54 Powerlock. The dash number for an A12 car would have been -3 or -5, not the -2, for the 4.10 gears. Built too late to be an A12 rear, anyway. An A12 rear would have been around February or April, plus or minus a bit based on build date of the car. That's just a rough estimate, but the date on your rear is too late, and A12s only came with 4.10 gears as well. Hope that helps! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] </div></div>
Right you are, the A12 were batch cars....forgot about that. Isn't the '71-'72 fuselage body B-bodies fitted with a wider Dana than the '70 b-body though - by a couple inches? </div></div>
Technically yes - they had two SPD's....329 and 426...but they were more or less built to almost the end of the model year.
Old 04-01-2016, 12:00 AM
MarcDant's Avatar
MarcDant MarcDant is offline
Measured the width and from outside to outside of flange, is 54 7/8 ,found these other numbers stamped on rear and carrier ,here are some pics ,tried to get both numbers in one picture on the carrier but the first number 8 is not recognizable due to bad photo skills.Thanks for the feed back.
Old 04-01-2016, 02:22 PM
We already know what kind of rear it is - 603109-2....70-72 and up B-Body, 3.54 Powerlock.
Based on the dates - it is for a 70 model year B-Body.
What are you thinking of putting it in?
Old 04-01-2016, 09:52 PM
MarcDant's Avatar
It would be a shame not to find it a home in a chrysler,it pushed a chevy for years in the late 80s early 90s.
Old 04-01-2016, 10:04 PM
I see them go for 1500-2500 depending on condition and application. E-body Dana's are worth a little more than B-body.....but still a good piece!
Old 04-03-2016, 02:46 PM
MarcDant's Avatar
Thanks for all the feedback, Im now sure of year and application and when i decide to sell i can give a better description of the unit.
