Old 03-01-2016, 01:57 PM
Default Re: Used enclosed trailer
You might consider a electric winch instead of a escape door. They make them with wireless remotes so you can walk around the car to see both sides as you are loading in.
Old 03-01-2016, 02:28 PM
Nice looking trailer. Thanks for the suggestion. I'll look into it.
Charley, I'd never heard of the wireless remote. I thought they all were hard wired by a cord to the winch. IT may sound like overkill, but I want both the escape door and the winch. Once I get used to it, I can drive the car in, but if it breaks, I'd need the winch.
There's something about the interior of this one (that I lost the deal on) that really appeals to me. Notice the inside fender boxes are only 6" high. The original owner had it built with a raised floor. (smart!) It's also a hidden dove tail.
Old 03-01-2016, 02:41 PM
Yes the wireless is just a key fob and really simplifies things. Also if you get a winch get one that uses a synthetic rope instead of a cable.
Old 03-01-2016, 02:48 PM
Something else to consider Verne is adding ramps all the way in be it aluminum or wood to raise the car a few inches in just those areas. I did my trailer with 1 3/4 blocks and the doors clear the wheel tubs. Doing that also gives you a little more clearance under the car to get at the tie downs. Most guys will run ramps all the way from the door to the nose. I instead mounted four 1'x1' blocks of wood so that the car rides up on them and that is where I stop. Just trying to give you ideas.
The remote winch is also worth every penny. I can actually sit in the car and pull myself in or let myself out with no assistance.
Old 03-01-2016, 02:54 PM
Caseys69 Caseys69 is offline
That sounds like a pretty sweet setup, who makes the winch youve got?
Old 03-01-2016, 03:00 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Charley Lillard</div><div class="ubbcode-body">You might consider a electric winch instead of a escape door. They make them with wireless remotes so you can walk around the car to see both sides as you are loading in. </div></div>
We borrowed a friends enclosed trailer to bring Dad's 409 home from the MCACN show last year (after the snow storm that weekend) and it had the wireless remote winch. It was our first time towing a car in an enclosed trailer and that wireless winch made us amateurs look like pros. We had the car loaded up and tied down in a matter of minutes and were on our way home. Saved a lot of headaches for sure. It also had the escape door which I think I would want too if we ever bought one as it is a nice feature.
Jake Dykstra
Dykstra Motorsports
Old 03-01-2016, 03:52 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Thanks for reposting the pics 67Novaboy.
The wireless remote is priceless with or without the get out door, but you can add it to any winch with a cheap kit. I added it to my circa 60s/70s winch. It works great. Yes, it's time to update my winch lol..., but it still works great although a little slow.
That trailer looks just like mine with some nice add-ons. I really like those cabinets, but I wouldn't want the floor. It looks like it'd be slippery when it got wet or had oil on it. Raised floors are nice, but then you lose head room which is only 6 1/2' usually to begin with. I like the idea of maybe two 2&quot; ramps to drive up on or something, but then you lose the point of the dropped trailer. Same goes with the raised floor. The ease of loading on a floor closer to the ground.
Something to also consider is what your hauling it with. All those add-ons add up and tongue weight adds up quickly. I wish I still had my F350 diesel then I wouldn't worry about it as much...
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Haulmark makes a good trailer, and they take a beating - ours is a '97 and while it looks rough on the outside I have the inside configured just the way I like with the big tool box and the spare mounted vertically behind it. I like the look of the cabinets, but could never understand how to best use that space - so I installed a tool cabinet and built a work bench top around it, with a vise! It has served us well, just a thought....
Sometimes it's more than just a work bench / tool cabinet!
Old 03-01-2016, 04:28 PM
68l30's Avatar
68l30 68l30 is offline
I bought mine about a year and a half ago. I did a ton of research and wanted the best I could afford. I did find out the Haulmark is not under the same ownership from days past. It was bought out by a larger corporation and the prior owner now bought Pace. I did buy a Pace. Again, do your homework on the build and the construction and materials used in fabrication and in the Axles. It make s a difference. I wanted floor centers on no less than 16&quot;, walls that were the same. The gauge of the outer skin, rivets or bonded sides, torsion or leaf spring, composite or plywood flooring, roof construction, yada yada yada. In the end, new was the only way to go to get what &quot;I&quot; wanted. In fact, it was cheaper in the long run because I didn't have to update and fix someone else's crap. If you're in a bad climate and it sits outside, where will the snow sit (flat roof) &amp; stupid roof vent? Will the floor rot quicker where it's parked?
BIG
Old 03-01-2016, 04:30 PM
68l30's Avatar
Add a winch....and spares....
