Old 01-28-2016, 05:07 PM
ted ted is offline
Default Re: 8 inch Balancer 3870325
Until I (we) get Mr. Furback's response re checking of his L78 balancer markings, may I summarize a couple of things?
The casting number 3870325 punched on the inner section of the balancer was used for many applications and cannot, repeat cannot in fact be used to identify a balancer specific to an engine's advertised HP rating(s).
Now, the numbers 9623 on the outer ring mean exactly what?? Are these numbers an abbreviation for 3879623 which in fact would make it good for 67 - 69 L88 and 69 ZL-1 engines.. ??
The code G2 F means ??
Thanks!
Ted
Old 02-05-2016, 06:36 PM
ted ted is offline
Good afternoon gentlemen!! Kinda waiting on Mr. Furback to check his balancer and the numbers on it. Anyone else able to break down the 9623 code on the front outer ring of my balancer.
Thanks!
Ted
Old 02-22-2016, 01:03 PM
ted ted is offline
Anybody got a pic. of the proper timing cover that would've gone along with this balancer. Got a couple hangin' around, but, I'd like to be correct.
Merci encore - Thanks again!
Ted in Montreal
Old 02-22-2016, 04:55 PM
SS69chevelle SS69chevelle is offline
The four digits are likely the last of the part number and the G2F is the date code, probably july 1972 or 82. Likely an over the counter replacement.
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
