Old 01-15-2016, 12:05 AM
Furback Furback is offline
Default Re: 1970 Z28 intake, carb, heads and air cleaner find
Who said that 492 angle plug heads came on a 70 Z??????
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1964 Ford short step
1929 Ford Coupe
1931 Ford Coupe
1986 GMC Wrangler 4X4
Old 01-15-2016, 12:06 AM
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1929 Ford Coupe
1931 Ford Coupe
Old 01-15-2016, 12:14 AM
Actually, 492 straight plug heads were used in late production 1970, part number 3987376, this was also the superceded part number for the discontinued "186" 1969 Z28 head. Early production 70 Z28,s/Corvettes had "186" heads before the "492" was used. The Z28 and Corvette LT1 had 2.02X1.60 valve size and screw in studs. The "492" head was also used in 350/300hp but was a 1.94X1.50 with pressed studs.
71,72 and 73 used "487" casting, it was a large chamber 2.02X1.60 on the Z28 and Corvette LT1. Low horse passenger cars also used this casting but as a 1.94X1.50 and pressed studs. A friend has some M dated 1.94 492 heads, he got them off a 300 HP Taxi.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1929 Ford Coupe
1931 Ford Coupe
Old 01-15-2016, 12:23 AM
Are you having a conversation with yourself?
Old 01-15-2016, 12:24 AM
LOL, no it is a quote. Seems that way though.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1929 Ford Coupe
1931 Ford Coupe
Old 01-15-2016, 02:15 AM
68moz28rs's Avatar
68moz28rs 68moz28rs is offline
I think you should do some research. 186 heads were 1969-1970. 487 were 71+. Use some google if you want to argue. They're all over the counter. And post some pictures if you really have 492 heads with straight plugs. They didn't make them.
Brandon
68 Camaro 302 Z/28 Rally Sport
68 Camaro Convertible w/427
68 Camaro Drag Car
67 Camaro Royal Plum RS/SS
67 Camaro Convertible 327 RS
92 Corvette Convertible Quasar Blue white top
http://www.ebay.com/sch/usa-1musclec...pg=&_from=
Old 01-15-2016, 04:20 AM
supercomp 8.90 supercomp 8.90 is offline
when did they come out with the 292 turbo head? I remember years ago seeing a set of turbo heads that a circle track racer had a machine shop turn the angle plugs into straight plug style to pass tech lol!!
Old 01-15-2016, 04:36 AM
I believe there were some 186 angle plug heads floating around. OTC only. 186 heads ran into late production LT/1s My deuce has them. Colvin's book is not always 100% correct.
We ran 292s on a small blk 406. They make a lot of power.
Old 01-15-2016, 04:54 AM
x77-69z28's Avatar
I have a set of 292 angle plug heads on my 69 Z. They do make a lot of power. It is a peanut plug as well.
Buddy
Old 01-15-2016, 05:04 AM
68moz28rs's Avatar
Jenkins used a set of 492s on his 331 sbc and made somewhere around 700hp. I bought the heads from Jenkins and they're in a museum. They have a huge amount of meat in them for porting and the build quality tops those other fuelie heads in my opinion. I've personally never used 292s but hear a lot of good stuff about them!
Brandon
68 Camaro Drag Car
