Old 12-30-2015, 05:58 PM
aawtech aawtech is offline
Default Re: NEGATIVE CABLE
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr. Chevy</div><div class="ubbcode-body">My cousin has a 69 Malibu with a 350 engine. He recently purchased the correct spring ring type battery cables and discovered that the negative cable is about 6-8 inches too short to bolt to the thermostat housing like the assembly manual shows.. He has tried some other parts distributors and all the cables seem to be the same length. He is certain he does not have a big block cable. Those only bolt to the passenger side of the block..
He has since figured the most likely problem is the posts were reversed on the original batteries. On his current battery the negative top post is on the left side of the battery as your looking at the front of it... In lieu of changing the battery, does anyone have any ideas on what he can do to make the cable fit like it is supposed to??
Thanks... Rich </div></div>
Guys, this is Donny from AAW. I would be interested in an original cable part number. We have all the original info from Packard Electric including the blueprints. We make the cables from those prints, and they are spot on. Now, with that said, we have run into a few instances where there were running changes, and that could be the issue here, not sure. What I could use is the part number off of an original cable that mounts the way you are all suggesting. I will say that in my 26 years of working here, the issue 99% of the time is that the battery is installed incorrectly (posts reversed), or the car has the incorrect battery in it. The repro batteries are not always correct. Send me an email to [email protected] and I'll be happy to do some research and hopefully, put this to rest once and for all.
Thanks, Donny
Old 12-30-2015, 06:41 PM
Woj's Avatar
Woj Woj is offline
Donny,
Here's what is on my '69 Malibu. It is a 350/300 car with h.d. battery and alternator, so I'm guessing this isn't the normal for 69 small block Malibu.
Part numbers are: positive - 6296702MP, negative - 6296750YF. The negative wire is approximately 34&quot; long and attaches to the rear alternator bracket/thermostat housing mount.
I've got a call in to a buddy with a low mile original Malibu to see what cables his car has.
Phil Woj.
Old 12-30-2015, 07:18 PM
Well done Phil [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 12-30-2015, 07:48 PM
cook_dw's Avatar
cook_dw cook_dw is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Unreal</div><div class="ubbcode-body">I thought 69 s/b Camaro attached to the upper alternator bracket, and b/b attached directly to the block. </div></div>
Upper alt bracket and t-stat housing. At least thats how it was on the ones I have seen.. Could have been HD battery cars though.. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 12-30-2015, 10:38 PM
Mr. Chevy's Avatar
Dan, Phil and Donny THANK YOU VERY MUCH for your help!!
Rich
Old 12-31-2015, 01:27 PM
spiker spiker is offline
Hi Donny, This is Mike, Richs cousin. OPGI, sent the neg. cable stamped #6296745 YF. Cable that came off is marked 6296750 YF. They told me that's all they have for the SB application and insisted its the correct cable. 6296745 is 26&quot;.
Old 12-31-2015, 01:48 PM
Woj's Avatar
Woj Woj is offline
Mike,
What was the part number on your positive cable?
Phil W
Old 12-31-2015, 07:56 PM
Phil, pos. cable is # 6296702 MP
Old 12-31-2015, 08:39 PM
Woj's Avatar
Woj Woj is offline
My buddy just checked another survivor car of his and it has a negative cable with a length of 26&quot; and a part number of 6296745YF. The positive cable on the same car is: 6289199ML. He said this was a heavy duty set up and that it required the battery to have the positive terminal near the fender. That is new to me.
Mike I think they gave you the shorter cable. There must have been several different combinations for 69.
I'll do a little more digging on this one.
Phil
PS. My cable codes match what is on the build sheet, so I know they are correct.
Old 12-31-2015, 08:48 PM
Yep....it`s one of those that no one had the correct answer.....very frustrating.
