Old 10-12-2015, 02:35 PM
Default Re: Clutch Recommendations
LUK is a Pep Boys unit. I'm putting one in Benjamin's '69 Nova, only because I know he'll toast it while learning to drive a stick.... The replacement unit will be a better quality unit, likely a GM unit since we will run street tires most of the time.
Old 10-12-2015, 05:00 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Maybe others already knew but what is the setup? Tires, trans, hp, tq, rear gears launch rpm & shift rpm?
Old 10-12-2015, 06:13 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: YENKO DEUCE REGISTRY</div><div class="ubbcode-body">LUK is a Pep Boys unit. I'm putting one in Benjamin's '69 Nova, only because I know he'll toast it while learning to drive a stick.... The replacement unit will be a better quality unit, likely a GM unit since we will run street tires most of the time.</div></div>
Honestly M its better than that. He will not toast a LUK setup. Call the Rep and ask him. Its good quality in a street unit.
Old 10-12-2015, 07:45 PM
turbojet427 turbojet427 is offline
Yenko Advertising Member
Full bodied 69 Camaro. 650+/-hp 427bbc. 4.10 rear with 28x9 tires. M23 Autogear Muncie 2.56 1st gear.
Old 10-13-2015, 02:17 AM
cook_dw's Avatar
I like the McLeod Twin Disc clutch. 800-1000hp rating and you can slip it with the organic discs and it holds extremely well at the track. I have used it several times with LS applications for street/strip cars they never had a problem. Could have been due to hydraulic clutch. Other than that I would recommend a Spec Clutch which again have ran on the street and strip and it worked great as well. I havent had a hard grabbing clutch that didnt chatter on the street a little..
Old 10-13-2015, 02:48 AM
scuncio's Avatar
scuncio scuncio is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: turbojet427</div><div class="ubbcode-body">Full bodied 69 Camaro. 650+/-hp 427bbc. 4.10 rear with 28x9 tires. M23 Autogear Muncie 2.56 1st gear. </div></div>
OK, you are way out of LUK territory now. [img]<<GRAEMLIN_URL>>/smile.gif[/img]
I have a McLeod Soft Lok in my 650 lb-ft Pontiac and it's rock solid but does chatter a bit on takeoff. Dual disc is a good bet here.
Old 10-13-2015, 03:34 AM
Hayes or Ram diaphram should work.
Old 10-13-2015, 04:16 PM
69 Post Sedan's Avatar
I'm running a Hays Street/Strip clutch.....it reminds me of the old Borg Warner Brute Force clutch I had in my old Nova. A little heavier on the foot compared to stock.....but IT HOOKS!
4000rpm launch, shifting at 7k with a 3600 pound car.
You'd be hard pressed to find someone harder on a clutch than me...... [img]<<GRAEMLIN_URL>>/scholar.gif[/img] [img]<<GRAEMLIN_URL>>/[/img]
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 10-13-2015, 04:23 PM
Ryan1969Chevelle's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69 Post Sedan</div><div class="ubbcode-body">I'm running a Hays Street/Strip clutch.....it reminds me of the old Borg Warner Brute Force clutch I had in my old Nova. A little heavier on the foot compared to stock.....but IT HOOKS!
Kurt </div></div>
This is what I will use on my W-31!!
If Kurt can't break it nobody can:-)
Ryan
Old 10-14-2015, 12:53 PM
napa68's Avatar
napa68 napa68 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: cook_dw</div><div class="ubbcode-body">I like the McLeod Twin Disc clutch. 800-1000hp rating and you can slip it with the organic discs and it holds extremely well at the track. I have used it several times with LS applications for street/strip cars they never had a problem. Could have been due to hydraulic clutch. Other than that I would recommend a Spec Clutch which again have ran on the street and strip and it worked great as well. I havent had a hard grabbing clutch that didnt chatter on the street a little.. </div></div>
I've got this in my 67 Nova (600hp). Rock solid and great manners. Not Cheap!
