Old 03-30-2015, 04:03 PM
Enoch Enoch is offline
Banned
Default Re: Trying to verify original radiator mounting bolts
This design started sometime in 70 not 69. your bolts should have a pinched point Recessed/flanged head. GM pt # 396014. And more specifically the M in a hex is late 70's early 80's from what I have seen. Original headmarkings for 69's would be RBW, E Anchor, $, 23 C and a few more. Hope this helps, Rich.
Old 03-30-2015, 04:07 PM
Woj's Avatar
Woj Woj is offline
I took a few pictures of the bolts holding my radiator on my 69 SB Camaro. It has 13k original miles on it (Ohio car). I don't think the radiator has ever been out of the car. I don't know if BB and SB had same mounting pattern, Mikey will know.
Here are the bolt from the driver's side:
Passenger side: Bolts have points:
Overall picture:
Old 03-30-2015, 04:08 PM
Woj's Avatar
Woj Woj is offline
PS. I can get bolt head markings later if you need them.
Phil Woj
Old 03-30-2015, 09:08 PM
69VN's Avatar
69VN 69VN is offline
Ok gents thanks for all the info. Good stuff! Phil if you like you can post some bolt head markings later.
Sal [img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
Old 03-30-2015, 11:10 PM
Woj's Avatar
Woj Woj is offline
Bolt head markings:
Driver's side with well nuts:
Passenger side:
Hope this helps.
Phil Woj.
Old 03-31-2015, 06:27 PM
Kurt S Kurt S is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">Kurt, over the years when refering to the 69 AIM on hardware issues the revision date of 10/xx/68 seems to be in the manual allot, any insight on that ?
Mike </div></div>
I'd guess that there were a bunch of changes after the 69 launch that took about a month to implement. [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Kurt S - CRG
