Old 03-23-2015, 08:48 PM
Damien Damien is offline
Default Re: '70 Chevelle Front Rotors
Thank you guys, some greta info there that I will check into and post some pics and info. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
1969 SS 396/350 Chevelle
Old 03-23-2015, 10:10 PM
You are welcome.....This is what this great web site is all about [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Looking forward to your pictures [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 03-24-2015, 08:18 AM
PM sent Rick.
Thank you.
Old 03-24-2015, 08:23 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ls6 Ragtop</div><div class="ubbcode-body">Damien,
If your car has it's original front backing plates they will tell which style rotor was on the car.
If the car has # 5463496 &amp; 5463497 it had 2 piece rotors.
If the numbers stamped on the backing plates are 5463565 &amp; 5463566 then it had 1 piece rotors.
All this info is useless if the plates are not original to the car.
The other way to know which style the car came with can be found on the build sheet of the car if you have one.
From memory I believe codes AS and DK are 2 piece codes and DT is 1 piece. I am traveling right now and can't reference my build sheet collection right now.
I would lean towards 2 piece rotors if your cowl tag date is 12 B but it could go either way in my opinion if it's 02 B.
I have seen cars built into March of 70 with 2 piece rotors.
My February built LS6 convert from the Baltimore plant has 2 piece rotors.
Hope this helps.
Chris </div></div>
Chris, I managed to find the 5463496 and what looks to be an L on the driver's side backing plate, but unable to get a decent pic though. So it looks like it had two piece rotors.
Thanks very much, you were a great help. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 03-24-2015, 08:30 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Great info Chris....since we are on the topic of early and later built '70`s......Damien also take a look at your tail lenses. Are they the early style - flat lenses? The same with your hood....is your hood an early hood? Take some pictures of the underside front portion of your hood and post them...again this only applies if your hood and tail lenses are original.
Plus I see your Chevelle has the lower trim under the front headlight bezels....another part found on early built Chevelles.....perhaps we will see a pattern here [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Dan </div></div>
Dan, I think you are correct.
Even though it has the round tail lenses rather than the flat, that may well have been swapped out at some stage, it looks to have an early style hood with the smaller triangulated inner structure?
Hood
Tail lense
Old 03-24-2015, 10:50 AM
Great! You need a set of 2 piece rotors and a set of flat rear lenses to make her complete [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Well done.
Old 03-24-2015, 11:37 PM
On the list Dan. Thanks for your input as usual. Big thanks also to Rick Nelson. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Great site here. [img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
Old 03-25-2015, 12:03 AM
Jefferson is coming up next month. If I find any early lenses....they are yours.
Old 03-25-2015, 12:27 AM
Thanks Dan. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 03-25-2015, 12:36 PM
Rixls6 Rixls6 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Jefferson is coming up next month. If I find any early lenses....they are yours.
Dan </div></div>
Check the parts for sale section here. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Rick
Don't text and drive.
