Old 01-31-2015, 06:49 PM
PeteLeathersac's Avatar
Default Re: 1969 Oldmobile W30
Congrats on what sounds like a very cool car!
Was it always a street car only or did he ever run it at the track?
Did the owner supply any original paperwork etc or any hope for anything still to come?
Either way, looking forward to pics and more details!
With respect to production #'s supplied by GM Canada Vintage Services also whether it be for Oldsmobiles or other GM brands, the reported #'s often seem sporadic being what they exactly represent is not always specified.
Usually the quoted #'s are for total body style shipped into Canada but whatever's supplied, using Canada's approximate 10 percent population of the USA as a guide and comparing known production #'s with quoted Canada reported #'s, sometimes a good indication of what they most likely represent can be revealed.
Back to the subject car, if the known production # of 2475 units is specific to the 1969 "4477" serial # 442 Post cars regardless of transmission, W31's being Cutlass and F85 cars having their own serial prefixes are separate and not included in this production #.
I believe #'s are known for the breakdown between manual and auto cars but for the moment just using the 10 percent Canada guide only w/ the known 2475 units produced, approximately 250 manual and auto 442 Post cars were delivered to Canadian dealers.
Again this is for the 4477 serial # cars so represents all 442 Post cars including any std. 400 CID 442's whether equipped w/ optional W32 air supply system or not <span style="text-decoration: underline">also</span> the W30 Post 455 CID cars of which all included W32 parts.
That all said and again not specifically Olds cars but all GM brands, using the 9 to 1 ratio USA/Canada thing as a guide and jiving known actual production #'s w/ any different Canada reported #'s could help reveal some actual #'s also indicate some approximate #'s for cars delivered on both sides of the border.
[img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
~ Pete
Old 01-31-2015, 09:38 PM
Jefferson's Avatar
Jefferson Jefferson is offline
My mistake everyone. Turns out to be a W32 model. Snapped a few pictures for viewing. If anyone has information on how many W32's were sold to Canada would be great. From an Olds book... it shows only 25 models sport coupes were built. The dealer info states Motors Insurance Corporation LTD. Annacis, BC. Car has a Dick Irwin dealer emblem. Leads to believe the car was delivered at the Annacis car distribution center then bought from Dick Irwin.
old5.0 old5.0 is offline
Man, I wish the other GM divisions had a service like PHS. Years ago, I had the front sheet metal and OAI set up off a 69 W30. The rest of the car was long gone, but I would have loved to get some sort of info on production numbers.
Old 01-31-2015, 10:00 PM
Fast67VelleN2O's Avatar
Interesting how you couldn't get a 4 speed with the W32.
Day 2 is Life.
Old 01-31-2015, 10:03 PM
Enlighten me briefly as to what the difference is between a W31 and a W32 is? (I don't speak Olds) [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 01-31-2015, 10:10 PM
W31 was all the hot rod W30 parts (OAI, big cam, etc) on a 350 Cutlass/F85. W32 is a standard 400 cube 442 with only the OAI equipment. That's it in a nutshell, as I understand it.
Old 01-31-2015, 11:42 PM
442w30 442w30 is offline
Suggesting a W-31 got the W-30 hot rod parts is not quite accurate since the 350 and 400 are of a different series of engines.
When I get the chance, I'll write at length where the W-32 fits in because it's terribly confusing and only an Olds product planner would know for sure.
But for 1969:
W-31 350/325
W-32 400/350 (some sources say 360)
W-30 400/360
Olds people will tell you the W-31 has the most potential of the bunch (even when compared to the W-30 455 from 1970).
Old 02-01-2015, 02:10 AM
Stefano Stefano is offline
Estimated real power output for a W-31 was 350 hp and upto 440hp for a 4 speed W-30 in 1970.
While the W-31 was a stout performer for 350ci, it could not run with a 455ci W-30. The W-30 also had substantially more torque and did not weigh much more than the W-31.
The only way to know exactly how many, W-30 or W-32 Posts were imported into Canada would be to review the build sheets of all the post cars, which GM of Canada has on file.
&quot;W32 is a standard 400 cube 442 with only the OAI equipment. That's it in a nutshell, as I understand it.&quot;...........this is correct.
Click to visit the Nickey Performance Facebook--&gt;
Old 02-01-2015, 02:45 AM
My point about &quot;potential&quot; is that the 350 is more impressive in performance than the 400 or even the 455, from a cid perspective.
Anyway, the standard 1968-69 4-4-2 engine was a 400 rated at 350 horses with a stick. However, if you got an automatic, it was 325.
So, yes, the W-32 seems to be a manual-tranny base 4-4-2 engine with an automatic and equipped with certain hi-po items standard like under-the-bumper air induction, 3.42 gears with Posi, etc. I've never compared the specs of the engine to see if it's exactly like the base manual 400 but if it's not, it probably has slightly higher specs but nowhere near the W-30's.
Old 02-01-2015, 04:17 AM
StriperSS StriperSS is offline
The 30's and 31's were kind of a factory balanced and blueprinted engine, as much as could be done in that setting. That, with the OAInduction made them pretty good performers.
According to my parts book, there was a difference between a 68 -69 400 short block with OAI, and one that was a Hi comp engine with OAI.
230824 was the hi comp
230822 was the exc hi comp
69 W-32 camshaft was a different part number 393859
69 W-30 &quot; 402569
