Old 08-26-2014, 06:03 AM
Kurt S Kurt S is offline
Default Re: Safest Rust Remover or Evapo-rust or ??
I didn't realize that vinegar (acetic acid) would work too. btw, CLR is a mix with 2 different acids.
Thanks guys!
Kurt S - CRG
Old 08-26-2014, 12:27 PM
Woj's Avatar
Woj Woj is offline
I have used metal rescue with very good results. I needed a large quantity, 10 gallons, and was able to obtain it through Home Depot. The stuff was delivered to my door for less than $200. I used it to de-rust some survivor 69 SS rims. I bought a 30 gallon plastic trash can, put in one rim at a time and let the chemical go to work. I didn't take any before and after photos though, but I was very satisfied with the result. I ended up using a cheapo $7 pond pump from Harbor Freight to move the fluid around. That seemed to improve the results. The good thing about this stuff is that it can be re-used.
Phil Woj.
Old 08-26-2014, 05:07 PM
70 copo 70 copo is offline
For reuse I have found that it is better to screen the bigger rust particles and flakes out of the liquid prior to storage.
Old 08-26-2014, 05:12 PM
firstgenaddict's Avatar
Evaporust is what I have used with excellent results in saving original phosphate coatings on hood hinges and hood latches, also works to remove the rust on Ebrake pedal assys very well.
The Original Paint Black Vintage Certified RS/Z had evaporust used extensively, I too believe it is the same as safest rust remover.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 08-26-2014, 06:42 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 70 copo</div><div class="ubbcode-body">For reuse I have found that it is better to screen the bigger rust particles and flakes out of the liquid prior to storage. </div></div>
Thats a must! If you do not screen out the rust particles that have fallen into the mixture the product continues to work and will break down the PH even sooner. Same goes for getting your parts as clean as possible before you soak them.
Old 08-27-2014, 01:05 AM
Stefano Stefano is offline
We use evaporust on a regular basis, to clean light surface rust on parts and sheet metal.
Click to visit the Nickey Performance Facebook--&gt;
Old 08-27-2014, 01:36 AM
302moz 302moz is offline
I have used evaporust for over two years. Works excellent.Purchased a 55 gallon drum over a year ago and its still going strong.The big thing is to keep grease/oil out of it and do a quick sand blast before. It has had engine blocks,heads,rear ends,sheet metal,steering boxes.rotors,intakes in it.I think every piece of my ta has been it at one time. John
Old 08-27-2014, 02:49 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 70 copo</div><div class="ubbcode-body">For reuse I have found that it is better to screen the bigger rust particles and flakes out of the liquid prior to storage. </div></div>
Thats a must! If you do not screen out the rust particles that have fallen into the mixture the product continues to work and will break down the PH even sooner. Same goes for getting your parts as clean as possible before you soak them. </div></div>
I think Rick's message is the key. I've used it but if I leave it sit after one use, it goes to pot on it's own. That's a major waste of money. Once it turns black, it's no good at all.
Verne [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Old 08-27-2014, 02:35 PM
bcmiller bcmiller is offline
There are several things that can be used, and I have tried everything mentioned. Depends on what you are using it on as to what will give the best results.
Old 08-27-2014, 08:31 PM
Temperature is something you need to closely watch. Cold solution will not be very effective short term while warm solution works pretty fast.
