Old 02-28-2014, 01:56 AM
x77-69z28's Avatar
Default Re: 71 Ralley wheel paint
The name of the thread on nastyz28 is "Z28 wheel finish"
Old 11-17-2018, 08:34 PM
Budz's Avatar
Budz Budz is offline
Originally Posted by roeville View Post
Yes, as mentioned above, the correct formula is DDL32961. If you search the NastyZ28 website you'll find more than enough info on this. I believe someone was recently able to get the lacquer formula from Year One. BTW, the wheels in your post (OP 6pakdave) look like 76 and later wheels.
- Mike
So is this actually the correct way to paint these, with the outer (front side) of the lip Dove Gray like the back and inside of the wheels? I painted my set of date matched 'show' wheels this way years ago, but for the life of me can't remember why. I don't think I've actually seen any in person this way.
Buddy
1970 Z28 Restored
1971 RS..project BBC..for fun
2002 35th Anniversary SS
Old 11-18-2018, 05:03 PM
Buddy, The entire front of the wheel was painted with the Lacquer "Cast Looking" Formula.
Anybody reading this know of a PPG Jobber that can still mix the above formula with SUEDE additive..
I have a very old unopened pint can that I'm thinking would be bad ??????
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
The Following User Says Thank You to CamarosRus For This Useful Post:
Budz (11-19-2018)
  #14
Old 09-05-2022, 11:13 PM
LOL...............Hear I am FOUR Years later....Still asking
1) Anybody reading this know of a PPG Jobber that can still mix the above formula with SUEDE additive..
2)I have a very old unopened pint can that I'm wondering if still useable ????
3) How many wheels (one side) might be painted with ONE pint of the PPG 32961 Lacquer..........
Chuck Sharin
[email protected]
Old 09-06-2022, 12:43 AM
L72Biscayne L72Biscayne is offline
If the can was stored correctly meaning it never froze, then I’d bet that it’s still good. I would think a pint would refinish the face of a couple sets of wheels.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
Old 09-06-2022, 03:25 AM
70post 70post is offline
You're probably going to need to reduce/thin the lacquer quite a bit prior to spraying so you should easily have enough for the wheels.
Patton Glade
70Post Restorations
Austin, TX
Old 09-06-2022, 02:24 PM
I usually start out at 1:1 reduction and see how it flows out. Nice thing about this application is that you won't be sanding between coats as you want to end up with a pebble finish.
Owned since 1978 - First Car
