Old 02-03-2014, 04:56 AM
Default Re: Derusting a flywheel.
Why pay to have the flywheel resurfaced if he doesn't need to. Is it really worn or just surface rust ? If it only needs rust removal he can use it over and over for years.
Old 02-03-2014, 05:13 AM
GaryC's Avatar
GaryC GaryC is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Charley Lillard</div><div class="ubbcode-body">Why pay to have the flywheel resurfaced if he doesn't need to. Is it really worn or just surface rust ? If it only needs rust removal he can use it over and over for years. </div></div>
Charley it needs to be surfaced anyway...it has a few raised spots from heat on it and a few small hair lines as well. I don't think it needs a lot removed but I have a new clutch to go with it so I may as well get it all done...I'm thinking balanced.
Gary
Old 02-03-2014, 02:05 PM
I used that safestrustremover stuff on an NOS flywheel (let it soak in the liquid) and it was amazing - brought back the original machined surface. I think evaporust is the same buffered solution liquid. Don't use the phosphoric acid based liquids on something like this because they convert the rust to a hard material, versus the buffered solutions which actually wash away the rust and stop when they reach virgin metal.
Old 02-03-2014, 05:21 PM
marxjunk marxjunk is offline
evsporust is amazing on carbs...i know its not rust on carbs,,but it makes them look new..BUT removes all the plating...really kills all the carbon and varnish..i used it on my GTO tripower carb and was amazed (i tried it on a useless carb first)bases which are cast iron came out like NOS...in appearance
Mark
Old 02-03-2014, 05:57 PM
GaryC's Avatar
Well let me ask you all something then. How bad does s flywheel have to be before it really needs to be resurfaced? I only just heard about Evap-o-rust this past summer, and at the very least I may just get some for other things that it can be used for. Maybe I'll just do the flywheel and then check it out then to see if it really needs resurfacing afterwards. Heck, it may not even need anything but cleaning, I have never had to get one done in my life time and this one may not even need it anyway.
Gary
Old 02-03-2014, 06:56 PM
What the machine shop does is, it gets it clean and then trues it up with a resurface. Its worth the 50 beans to me for that service!
Old 02-03-2014, 07:26 PM
68l30's Avatar
68l30 68l30 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">What the machine shop does is, it gets it clean and then trues it up with a resurface. Its worth the 50 beans to me for that service! </div></div>
^^ That and it ain't worth f'n up a clutch disc and doing the job again... [img]<<GRAEMLIN_URL>>/scholar.gif[/img]
BIG
Old 02-03-2014, 08:18 PM
GaryC's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 68l30</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">What the machine shop does is, it gets it clean and then trues it up with a resurface. Its worth the 50 beans to me for that service! </div></div>
BIG </div></div>
Totally agree. This is something I hated messing with anyway if you don't have a lift. I have done a few with and without one and would rather do it once without a lift.
Thanks guys, I believe I know what my plan is for the flywheel now. All good info, I appreciate it. Do it once and do it right the first time. There is a local NAPA and a Manlove in my area I can take it too, but I believe it goes out to someone else from there, I'll have to check on that. Heck it may even go out of state if that is actually done.
Gary
Old 02-03-2014, 08:29 PM
Sounds good Gary! Case closed on the flywheel. NEXT.........
Old 02-03-2014, 09:27 PM
GaryC's Avatar
This summer I plan on being busy. Tracton bar install, just about have all I need for putting the 302 back in the car except the head gaskets. Not exactly been able to find any good answers there, many opinions, but nothing concrete, especially for a stock rebuilt .030 over 302. Block is assembled, heads are done, distributor is ready, points and/or electronic, carb is fresh restored...but the head gaskets are holding me up. At least a dozen has been suggested but in the past year GM 10105117 and 3830711 are my choices. one is composite and the other is a shim.
That is what is next.
Gary
