Old 10-19-2013, 12:36 AM
Bus Bus is offline
Default Re: nova ss 350 lt1
Ok the motor is out at my grandpas farm ill have to go out and get some pics
Old 10-19-2013, 04:20 PM
That VIN is not on the Yenko list and the color is not correct for the Deuce...
As for the 010 block and 186 heads...these were the same casting numbers as the 300hp base L48 engine. The only difference was the LT-1 motors had 2.02 intake and 1.60 exhaust valves plus the screw in rocker studs (the double hump casting mark was the same)...the block was the 4 bolt version in either case...
The only way to tell for sure what motor you have (original application) is by the deck stamp on the pass. side front of the block...that will tell the story. Lots of parts can be changed and moved around in 40 years...get some more info...post some pics.
wilma
Old 10-20-2013, 12:33 AM
I believe that's the body nbr off the trim tag, and we do not have all the VIN nbrs, or inventory sheets.
Color probably excludes it unless it was a Canadian COPO, but I really doubt that. Air would be the nail in the coffin.
Old 10-20-2013, 01:38 AM
Good catch Ken on the body number...I just picked up the term "VIN"...
The color and A/C still make this a doubtful find...maybe we will see some pics soon.
wilma
Old 10-20-2013, 11:26 AM
iluv69s iluv69s is offline
aren't there a few canadian COPO novas that are not dueces ??
Old 10-20-2013, 03:04 PM
Bus Bus is offline
So I found a number for the motor its vo309cnj
Old 10-20-2013, 03:10 PM
Bus Bus is offline
That came off of a 1970 pre delivery service and adjustment sheet
The cars serial number is 114270w292122
Trans number pob26
The axle number is cbs0324w
And it has a 1331 stamped on it
It came from a paus motor sales in west point, NE
Old 10-20-2013, 03:14 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bus</div><div class="ubbcode-body">So I found a number for the motor its vo309cnj </div></div>
cnj code should be 350 300 hp i believe...
Old 10-20-2013, 08:49 PM
Bus Bus is offline
I talked to the original owner and he said he ordered it with a 350 lt1
Old 10-20-2013, 08:51 PM
Bus Bus is offline
Sorry just a 350
The Following User Says Thank You to Bus For This Useful Post:
CalJim (11-19-2024)
