Old 09-26-2013, 03:42 AM
firstgenaddict's Avatar
Default Re: Fan Clutch R & R
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: smoke' em II</div><div class="ubbcode-body">Amazing, looks way better than the NOS pieces that I have seen!!! Can you tell that it has been taken apart at all? I was getting ready to send one of my original Eaton fan clutches to Kirk, but was trying to figure out if you can tell that the front plate was removed and welded/ brazed back on.
[img]<<GRAEMLIN_URL>>/drool.gif[/img] [img]<<GRAEMLIN_URL>>/Can-I-Have-It.gif[/img]
http://www.kirkconnellcorvettes.com/ </div></div>
The TIG welding is on the aluminum lip which is then machined down to the original profile in order to re-seal as original.
It is only the process to repair the original crimped down lip which is either broken or fractured when disassembling the units.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 09-26-2013, 04:46 PM
smoke' em II's Avatar
smoke' em II smoke' em II is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: firstgenaddict</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: smoke' em II</div><div class="ubbcode-body">Amazing, looks way better than the NOS pieces that I have seen!!! Can you tell that it has been taken apart at all? I was getting ready to send one of my original Eaton fan clutches to Kirk, but was trying to figure out if you can tell that the front plate was removed and welded/ brazed back on.
</div></div>
After Kirk is done, can you tell that this area has been re-welded or is the repair totally un-detectable?
ACES #08588
OCA #28054
1970 Chevelle SS
1970 Olds 442 Survivor
1997 SVT Cobra convertible
Old 09-26-2013, 05:33 PM
mockingbird812's Avatar
How much?
Sam...
Old 09-27-2013, 01:20 AM
x77-69z28's Avatar
The website states $225 Sam.
Old 09-27-2013, 11:15 AM
70 copo 70 copo is offline
I have a Photo I came across while doing the research for the book showing a detailed clutch fan part illustration. I will post it here later today. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-27-2013, 05:00 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: x77-69z28</div><div class="ubbcode-body">The website states $225 Sam. </div></div>
Thanks Buddy. Nice resto.
Sam...
Old 09-27-2013, 08:37 PM
737Driver 737Driver is offline
Mine was $270.00 because he performed a 'shaftectomy' on it. He installed the short shaft.
Mark Donnally
2002 Chrysler T & C Minivan (Ol’ Nelly)
322,946 original miles
All numbers match...something
New carpet and headliner
New AC system, blows cold in the winter
It ain't for sale so, don't ask
Old 09-27-2013, 09:26 PM
m22mike's Avatar
m22mike m22mike is offline
Holy cow, that sounds like a medical procedure...ouch... [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 09-27-2013, 10:01 PM
The parts that comprise the fan clutch assembly are: (clockwise starting at the right hand)
Studs, Shaft, Cover plate assembly, pump plate, clutch plate, gasket, body, bearing,
external bi-metal arm, and shaft assembly.
Old 09-28-2013, 06:00 AM
MosportGreen66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">Holy cow, that sounds like a medical procedure...ouch... [img]<<GRAEMLIN_URL>>/hmmm.gif[/img] </div></div>
Mike, basically is. Mark - correct me if I miss speak for your application, but at least on the units he's done for me, I've sent small block original clutches and he rebuilds them as original appearing big block units. Passes judging 10 of 10 times!
