Old 12-12-2013, 03:51 PM
firstgenaddict's Avatar
Default Re: JetFire
Isn't that the same engine design Range Rover put in their vehicles until recently?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 12-12-2013, 04:52 PM
Default Re: JetFire
----Yes!!!.....Bill S
Old 12-12-2013, 05:17 PM
earntaz earntaz is offline
Default Re: JetFire
Same as the Buick?
Old 12-12-2013, 08:52 PM
Default Re: JetFire
----No!.....Bill S
Old 12-12-2013, 10:10 PM
travlnz28 travlnz28 is offline
Default Re: JetFire
Greg,
Put me in line for a ride when you get it done!
Gregg
Old 01-10-2014, 06:43 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Default Re: JetFire
You got it Gregg. When it ever gets done. Still waiting on some parts. Turbo Rocket Fluid tank is installed. It gets pressurized by the Turbo to the same PSI (6-7PSI)and injects the methanol/water mix into the carb to prevent detonation and add a little power. Maybe substitute Nitro Methane? This really is a well engineered system. The only problem was customers not keeping fluid in the tank. A light on the Boost gauge would come on warning of low fluid. The wastegate would open and a 2nd throttle body would close to prevent engine damage. Customers would bring the car to the dealer and complain of low power!
Spare bottle to use on the road if you ran out:
Old 01-10-2014, 08:49 PM
Default Re: JetFire
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Same as the Buick? </div></div>
It's a Buick 215 V8. Buick did all the design and cast all the blocks, and it was first available for the 1961 Buick, Olds, and Pontiac line. Obviously, the front mounted distributor was a telltale sign that it was NOT an Oldsmbobile or Pontiac engine, but it was still marketed as a &quot;Rocket V-8&quot; by Oldsmobile, and as an &quot;...available 155 hp aluminum V8&quot; in the Pontiac Tempest.
Mickey Thompson entered a stock block Buick 215 V8 in the 1962 Indianapolis 500 (driven by Dan Gurney). It was the only non-Offenhauser engine in the entire field, and Gurney qualified 8th, retiring about halfway through the race with a trans/rear end problem.
Buick abandoned this casting a few years later due to a very high scrap ratio. They had massive porosity problems, which resulted in massive oil leaks. The aluminum Buick 215 V8 was discontinued after 1963. They sold the the design, tooling and manufacturing rights to British Leyland (Rover/Jaguar/Triumph), which evolved into 3.5, 3.9, and 4.2 liter engines for many British cars, like the Land Rover, Rover 3500, TVR, TR8, and in the early 70's was available in the MG.
In 1980, Pontiac introduced their Turbo Trans Am (and Turbo Formula), using the 301 V8 as the platform. Many automotive writers of the day erroneously billed that as the &quot;first turbocharged American V8&quot;, but that incorrect. Oldsmobile had the first turbocharged American V8 with their 1962 Oldsmobile Jetfire.
The Oldsmobile Jetfires were cool little cars. I really like them. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 01-10-2014, 09:29 PM
markus37 markus37 is offline
Default Re: JetFire
Buick and Olds versions used different cylinder heads..different bolt patterns too.Lance Reventlow ( of Scarab racecar fame ) did a lot of development work on these engines for early midengine racecar use...before the Can Am series.
Old 01-10-2014, 09:32 PM
69SSZL1's Avatar
Default Re: JetFire
Yes, thats right. And the only difference between the Buick and Olds versions was the pistons and heads. Olds used the combustion chambers to get various compression ratios like Chevy did, the Buick 215 used different pistons and the same nailhead looking type heads on their versions. Olds also had an extra headbolt around the cylinder, like the ZL-1 has.
The Jetfire was the WORLDS 1st turbocharged production passenger car engine!
Old 01-11-2014, 07:15 PM
jimbo jimbo is offline
Default Re: JetFire
Neat car.
What is the back story on the car?
Where can you buy the &quot;rocket fluid&quot;?
