Old 02-14-2013, 11:00 PM
jasonL78 jasonL78 is offline
Default Re: Body mount bolts and washers
These are out of a southern 68 nova. Are you talking about the front thick washer or spacer?
Looking for the next project.
Old 02-14-2013, 11:25 PM
My originals are right at .125" or 1/8" thick.
The replacements I got with the poly bushings are barely thinner at .118".
I also have some from a 70 Nova, and they are just barely thicker than my originals from the 69 Camaro. They too are pitted.
I can live with the difference, but the replacments appear to be simple hardware grade, and they distort too easily.
Would like a good grade 8 washer. 5/8 hole, about 2 and 7/16 outside diameter and close to 3/16 inch thick.
Old 02-14-2013, 11:42 PM
Not sure if you have a machine shop close by. They can always take a solid piece of steel turn it down on a lathe, drill the 5/8 hole, and cut them to the correct thickness for you. Just an idea.
Old 02-21-2013, 12:17 AM
jasonL78,
What are the head markings on your subframe bolts?
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
2019 Corvette Grand Sport
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
Old 02-21-2013, 01:39 AM
I will have to look for you.
