Old 05-04-2012, 01:44 PM
Plowman's Avatar
Plowman Plowman is offline
Default Re: NOVA REVING HIGHER
Start from standing still in 4th gear hard,if the clutch is weak this should tell you if the clutch is slipping alot. Do check the free play,should be a inch.
Old 05-05-2012, 04:19 AM
BJCHEV396's Avatar
I did research into the 4 large binders of info that came with the car.According to the records and bills the clutch was last replaced in March,1984.So I'm thinking clutch disc,pressure plate,release bearing and pilot bushing.Resurface flywheel.And check clutch shaft and shifter bushings.
