Old 02-03-2012, 06:28 PM
Default Re: '70 Z-28 starting features, etc
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Verne_Frantz</div><div class="ubbcode-body">.... That's when cars stopped being designed by stylists and built by engineers and began to be designed by lawyers and built by accountants.....Verne [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] </div></div>
Cool - I get to build cars now! Ha, and people say Accountants can only do numbers! [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 02-04-2012, 01:26 AM
markjohnson's Avatar
That feature of the car needing to be in reverse to remove the key is just a great indication of a car that's probably had a decent, cared-for life without being monkey'ed around with too much, Verne. A few years ago, my 1970 GS Buick, Factory 4-Speed car had the same thing and it was new to me also. It's such an easy thing to just leave it off the car if you do any exhaust modifications, clutch replacement, or Hurst shifter replacement. I thought it was pretty neat actually but I'd really hate to have to try to dig that stuff up to re-install if it was missing from a car!
Old 02-04-2012, 04:08 PM
Hi Mark,
I would agree with you. Not only did Day-2 mean the addition of a lot of parts; it also meant the removal of some. This car has 46Kmi on it and lots of original well cared for pieces. We're looking forward to a reasonably warm Sunday later this month when he'll bring it down here.
He's a little nervous about the front spolier. The original got broken and had to be replaced (hard to find) so we're going to see if it can be removed easily and only used for shows.
Old 04-09-2012, 01:29 AM
Well, the day finally came and Larry brought down the car for me to see and test drive. One correction about the engine. It is a CE block replaced under warranty. Here are some photos.
Excuse the disconnected gas pedal. This was after my test drive and a hard right foot.
The car runs great. Very &quot;user-friendly&quot; for normal driving but with the punch on command.
Verne [img]<<GRAEMLIN_URL>>/[/img]
Old 04-09-2012, 01:38 AM
This a Los Angeles built car, which I'm told has some unique features, such as a smaller gas tank, the evaporative emissions system with a return line to the tank, and the benefit of build sheets. This car has solid documemtation.
He also wanted me to ask the professors here if this was the origial gas cap for this CA car.
Any comments regarding correctness would be appreciated. He wants to strive to make sure everything is as it should be.
Thanks
Verne [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 04-09-2012, 02:39 AM
DarrenX33's Avatar
https://www.yenko.net/ubbthreads/ubbthrea...6149#Post436149
1969 Z28
1972 Corvette
Old 04-09-2012, 02:46 AM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is offline
That's my old Z28 that I restored.....I've talked to Larry many times on the phone already....seems to be a very nice guy...
1970Camaro Z28
Old 04-09-2012, 03:42 AM
x77-69z28's Avatar
randy or verne. does the p-o-p have replacement ink stamped on the front? i also have a forest green 70 z with a CE block. my p-o-p has an ink stamp on the front as a &quot;replacement&quot; it is also typed in the aluminum blank with no tape.
Old 04-09-2012, 04:07 AM
He has it mounted on a display board so I wasn't able to examine both sides.
Old 04-09-2012, 05:01 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: x77-69z28</div><div class="ubbcode-body">randy or verne. does the p-o-p have replacement ink stamped on the front? i also have a forest green 70 z with a CE block. my p-o-p has an ink stamp on the front as a &quot;replacement&quot; it is also typed in the aluminum blank with no tape. </div></div>
Yes, it does.It was explained to me when I bought the car that a new POP was issued when the block was replaced in 1971
1970Camaro Z28
