Old 12-05-2011, 01:32 AM
Default Re: 63 Corvette SWC L84 Restoration
What component do you feel is not original to the car, the dates and stampings seem to line up - or is there something unique that I'm missing?
Old 12-05-2011, 01:39 AM
napa68's Avatar
napa68 napa68 is offline
I myself, think the stamping on the deck would be deeper. Just from my own obsevations through the years, the stamp is more defined. But, it is just my opinion. As for the dates of the block, it is spot on.
Sill looking for a set of 461 heads from early to mid September of 62!
Old 12-05-2011, 03:03 AM
----Its really no big deal, but the water pump has been replaced. I like this car a bunch. one of my favorite 63/64 color combos......Bill S
Old 02-11-2012, 12:58 AM
napa68's Avatar
I have been collecting parts, getting after the build of the engine and transmission, and just preparing to set the drivetrain in the car for this year.
Looks like I am going to have a big project coming up with work this year so I am going to just drive the car for a year or two before I think about tearing into it.
I found the prefect virgin 461 heads!
Old 02-11-2012, 01:04 AM
napa68's Avatar
I stabbed in a cam from an LT-1. I have had great success with this prior in another F.I. 63 I had. The engine is .060 over with a compression ratio of 10:1. Experience dictates with the fuel injection, I'll be just fine on pump gas with 38 degrees total timing.
I found some original head bolts for the exposed heads. Otherwise, it's all ARP.
Old 02-11-2012, 01:11 AM
napa68's Avatar
The transmission has been a real trip. After is all said and done, it WILL be brand new outside of the case. Most everything was junk. What I am going to do here (to suit my own taste) is install a wide ratio cluster. The 2.54 1st gear will work quite a bit nicer with the 3.36's while still being a good road gear. Again, experience from my prior F.I. car, there is more than enough torque and RPM range to account for the RPM drop between gears of the wide ratio cluster.
Old 02-11-2012, 01:19 AM
napa68's Avatar
And in with the new!
Using the 2 degree sliders to keep this from popping out of gear!
Old 02-11-2012, 03:54 AM
Very nice Tim!
Old 02-12-2012, 02:56 AM
427TJ's Avatar
427TJ 427TJ is offline
I love everything about this car! Wheelcovers, ribbed blackwalls, dark color, fuelie, split-window.
Old 02-23-2012, 12:22 AM
napa68's Avatar
Got the transmission back today. I suppose I am going to stab it in this weekend.
