Old 11-14-2011, 05:51 AM
Mayhem's Avatar
Mayhem Mayhem is offline
Default Re: Mayhems 71 Nova
No, but oh I wish!!!
"Do you feel more like you do now than you did a few minutes ago?"
71 Rally Nova sbc
72 SS Pro Street Nova bbc
69 SS Nova bbc
Old 11-14-2011, 05:42 PM
Good grief, that is friggin' awesome.
John 10:30
Old 11-24-2011, 07:06 PM
Mayhem's Avatar
The new model Holley "HP" carbs work very well and look good too.
71 Rally Nova sbc
69 SS Nova bbc
Old 11-25-2011, 03:08 AM
miket1 miket1 is offline
The Nova looks great, how do you like the new Holley HP Carbs, is the idle quality greatly improved from the older version carbs.
69 Z28 Burgandy
Old 11-25-2011, 09:03 AM
Mayhem's Avatar
Thanks.
I am still tweaking it a bit, as I replaced the plugs to a little cooler plug the day after the carb, and am in the middle of doing the plug wires. I had some trouble getting the right plugs, as it is an '80 Vette motor, with aluminum heads. There are several options, which include a shorter and longer plug. I ended up going with the longer one = AC Delco 41-602 gapped at .045. The old ones were gapped at .041, so it runs a little different now.
But yes, it does seem to idle better, or at least make the cam lobe more of a gallop.
I had it burning tires through all of first gear and into half of second before I changed plugs. Now I have to tweak it again to get it exact.
I looked at the "Avenger" models with the pretty anodized body, but the HP version was more like a Dominator, with 4 matching barrels instead of the stock looking butterfly primary portion. The HP's have no choke, are mechanical secondaries, and are "street/strip" rated with an all business design.
71 Rally Nova sbc
69 SS Nova bbc
Old 11-25-2011, 09:06 AM
Mayhem's Avatar
P.S. &quot;burning tires&quot; into second gear on pavement equates to the picture at the top of this page for what it will do on a well treated track! [img]<<GRAEMLIN_URL>>/smile.gif[/img]
&quot;Do you feel more like you do now than you did a few minutes ago?&quot;
71 Rally Nova sbc
69 SS Nova bbc
Old 11-25-2011, 09:35 AM
Mayhem's Avatar
<span style="font-weight: bold">When you feel like running no hood.....</span>
71 Rally Nova sbc
69 SS Nova bbc
Old 11-25-2011, 02:13 PM
I need 2 of these for 540 cu. inch Merlin engines on my Fountain Powerboat, I am looking for good idle qualty, Holley says with the 4 corner idle adjustment &amp; new designed air bleeds that at idle it is more tunable and sharper, that is what I was curious about compared to the older version Holley carb.
69 Z28 Burgandy
Old 11-25-2011, 03:08 PM
PxTx's Avatar
PxTx PxTx is offline
My sister has an HP on her camaro, it probably 8 years old. It is def richer out of the box than a standard Holley.
The air bleeds make it a lot more tunable. If you are going to run two of them, you'll have to really look at the idle circuit. May be able to rune wiht a bleed, if they give you thant ability. When my dad and I tune the old 1850 600 cfm carbs for dual quads we would tyically put a small restrictor wire in the liquid line of the idle circuit in the metering block.
Paul III
Old 11-25-2011, 06:51 PM
Mayhem's Avatar
Mike, as you state, with the 4 corner adjustments, once you get the floats happy, they are awesome, and seem to be much more responsive and fine tuned than say a Demon.
They of course have the interchangeable power valve on the primary as well.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: miket1</div><div class="ubbcode-body">I need 2 of these for 540 cu. inch Merlin engines on my Fountain Powerboat, I am looking for good idle qualty, Holley says with the 4 corner idle adjustment &amp; new designed air bleeds that at idle it is more tunable and sharper, that is what I was curious about compared to the older version Holley carb. </div></div>
71 Rally Nova sbc
69 SS Nova bbc
