Old 07-12-2011, 02:54 PM
John Brown's Avatar
Default Re: well my ZL-1 engine finally showed up...
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: black69</div><div class="ubbcode-body">.....I know I have to change out the blower cam.....</div></div>
Generally blower cams are quite mild. You could have it run on a cam profile machine to see if it is suitable for what you plan on doing with the engine.
John Brown
Old 07-12-2011, 07:26 PM
black69 black69 is offline
well, before anyone puts too much effort into what this is, here is the scoop I just learned.
By preventing oil from dripping on the cam, and thus down to the crankshaft, you save power and you preserve what the windage tray in the pan is supposed to achieve. You do not want the crank coated with oil.
I was told to leave this in the engine, and there is no need to remove it. I hope those that have never seen this before enjoyed it.
Engine is a ~468 (learned that today).
bob
Old 07-12-2011, 08:09 PM
iluv69s iluv69s is offline
Bob....just read your post..I had a similar block that I sold a few years ago..I think it ended up in Canada..it has the same cast numbers, cast snowflake, stamped numbers, etc.etc...it was an early Yenko block..it also was a tall deck block..I am not sure if they all were tall decks or not..but You could probably check yours...I will try and dig up some old pics I have...
as far as max HP for a ZL-1 block, Ive had 2 complete ZL-1 motors with over 750 HP....They were and stilla re the most radical-racing oriented option ever put in a Chevy..imo..
Good Luck with it!!!
Old 07-12-2011, 08:39 PM
post some pictures if you can find them. its good to hear others have run across these, to compare stampings, info. I don't know how to tell its a tall deck block, but it does look like there is NO more deck room left near the water pump housing to me (thus normal deck?).
I would imagine most of these would have been run to death and then discarded for scrap. When I asked Verl Stevens on a guesstimate of the power it could run (thinking concervative 600 HP), he chuckled (and then I felt like an idiot). I probably should have started my first guess at 700HP.
Old 09-21-2011, 10:27 AM
My engine was supposidly in a dragster, and now I have it based on research, it was in a rail. Still trying to run down who did the first build that tried to squeak every once out of it as far as horsepower potential, and thus find its true home.
I thought some would enjoy speculation, i.e. the chevy ZL-1s making the numbers in 71-74 were actually yenko zl-1s. One of the top guys was a little too close to don yenko's location to not wonder [img]<<GRAEMLIN_URL>>/smile.gif[/img] He was a little over 2 hrs away from cannonsburg.
check out the list of record holders. there are 2 pages.
http://www.draglist.com/draglist/cat...Extended#53613
Old 09-21-2011, 02:40 PM
JoeC JoeC is offline
Yenko was given permission by Chevy on Aug 1, 1974, to purchase ZL1 blocks from Winters Foundry.
Before that, they were bought through Chevy
Old 09-22-2011, 11:53 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JoeC</div><div class="ubbcode-body">Yenko was given permission by Chevy on Aug 1, 1974, to purchase ZL1 blocks from Winters Foundry.
Before that, they were bought through Chevy </div></div>
My block is obviously before this 1974 arrangement, and is from the laporte foundry. To me it is possible, those drag cars making the times before 1974, were reinforced 052 blocks made by yenko (like the one I have). Thats my thought for the day.
Why the yenko stamping are hidden behind the timing cover is interesting also. Why did he do that....
From the outside it looks for the most part as a 052 standard block.
