Old 11-24-2010, 04:26 AM
Default Re: Lift stop cable unit
The application on the instruction sheet shows:
1965-1969 Chrevolet Engines left side 396-427.
Except 1969 with air cond AND air injector reactor (A.I.R.)
I'm still not 100% sure it was suppose to go on so many cars, and not Chevelles, but I think it's a cool addition, so I will be putting it on the Chevelle. It's certainly simple enough to remove, if I learn more aboutnitin the future. Thanks formall the responses. BRs
69 El Camino
69 Nova
C7 Vette
Old 11-24-2010, 04:56 AM
Donnie's Avatar
Donnie Donnie is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69 Post Sedan</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">A redesign of the motor mount with interlocking internal plates inside the molded rubber, eventually rendered the recall kit obsolete.
[img]<<GRAEMLIN_URL>>/scholar.gif[/img]
</div></div>
When did the redesign of the motor mount take place? That alone would answer a lot of questions. I know the instructions I had to the recall kit I just sold was dated 1971.
Kurt </div></div>
<span style="font-weight: bold">The new anti-lift mount went into use for the 70 model year. (Per the Sep-Oct 69 Chevrolet Service News) </span>
my drawback from using it on a 69 L78 Chevelle is the instructions say except A.I.R. cars
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 11-24-2010, 05:08 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Donnie</div><div class="ubbcode-body">[quote=69 Post Sedan][quote=njsteve]
my drawback from using it on a 69 L78 Chevelle is the instructions say except A.I.R. cars </div></div>
Donnie...Actually the instructions say: With air conditioning {And} A.I.R., because the ac cars with A.I.R had different smog tubes, for the lift stop bracket to fit. So if the car had either AC or A.I.R. it should fit. I tried the bracket, and it does fit around the smog tubes.
69 El Camino
69 Nova
C7 Vette
Old 11-24-2010, 05:13 AM
wheelhop wheelhop is offline
Well I've already been wrong once on this post but I think the motor mount problem was fixed by the 70 model year.
Old 11-24-2010, 05:31 AM
69 Post Sedan's Avatar
You're right Bill. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] I guess it can be taken both ways. So what you are saying is it won't work if you have A/C <span style="text-decoration: underline"><span style="font-weight: bold">AND </span></span>A.I.R.
I think everyone thought it wouldn't work if you had either one....including myself.
Although I did see a couple of Chevelles in our group at the MCACN show that had them installed.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 11-24-2010, 06:15 AM
Kurt S Kurt S is offline
It was a total bandaid solution to a major recall issue. As if the block bouncing up and down is good for the drivetrain or acceptable to the customer.
Chaining the block down instead of putting in new mounts = cheap bandaid.
Put in the good mounts and leave the chain on the dog....
Kurt S - CRG
Old 11-24-2010, 06:00 PM
al8apex al8apex is offline
ok, I knew I had some pictures
Here are the differences between the BB B body kit and the BB F/X body kit, just the ONE cable, that is it!
Note how Chevelle is not mentioned ... and t<span style="font-weight: bold">he date on the bottom of the instructions is December 23, 1971</span>
B body instructions:
F/X body instructions:
Differences of both kits:
Jim R
Scottsdale, AZ
Old 11-25-2010, 12:29 AM
427TJ's Avatar
427TJ 427TJ is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body"> The recall was due to the fact that the driver's side motor mount could break under certain &quot;abusive&quot; conditions, causing the engine to lift on the driver's side, thereby causing the mechanical throttle to be pulled to full WOT condition without the ability to release itself, since it was now at full throttle, causing more of a high-horsepower, torque-over condition, pinning the carb at WOT till the engine blew up, the car crashed, or the driver was intelligent enough to turn the ignition key off, diffusing the impending explosion. </div></div>
I was intelligent enough to shove my foot under the gas pedal and unstick the WOT! (High school, 1979, driving my buddy's stock L35/M40 '67 SS396 Camaro. That's how we learned the engine mounts were broken.)
Old 11-25-2010, 03:18 AM
ChevyThunder's Avatar
ChevyThunder ChevyThunder is offline
An unfortunate piece of triva .. for those of you that remember the movie , &quot; remember the Titans&quot; it shows Gerry Bertier getting broad sided in his Camaro . That movie was unfortunately only loosely based on fact . The accident was caused by the motor mount issue and WOT . Because of this accident with Bertier we have laws in this country championed by Gerry that help make public place more easily accessible for those in wheel chairs. From Wikipedia
On December 11, 1971, Gerry Bertier attended a banquet honoring the players of the 1971, T.C. Williams Titans football team for their undefeated season. After the banquet, Gerry borrowed his mother's new Camaro. Bertier lost control of the Camaro and crashed into a utility pole. The cause of the accident was determined to be a mechanical failure in the motor mount of his engine[1]. Following the accident, Bertier was rushed to the Alexandria Hospital in critical condition. After initially stabilizing him, the doctors determined that his lungs had been pierced by his sternum, which went into his spinal column.[5] Because of the severity of his injuries, Bertier initially had to be operated on in the X-ray room, only moving to the operating room when he was stabilized.[5] Although doctors tried to relieve pressure on his spine to help him regain some feeling, it was unsuccessful. Bertier would live the rest of his life paralyzed from the waist down.[5]
A month after the accident, Bertier accepted an award for being the most outstanding defensive player in the metropolitan area, a ceremony he arrived at in an ambulance. Bertier had difficulty adjusting to paralysis and life in a wheelchair, confessing to assistant head coach Bill Yoast that &quot;it took him two years to accept the fact from the time of the accident that he would be crippled for life.&quot;[3] Once he did accept it, nothing held Bertier back from helping others. Bertier told his mother, &quot;I don't care if I'm paralyzed. God left me with my brain and I'm going to use it to help people less fortunate.&quot;[5]
During the next year, Bertier coordinated with Alexandria Junior Colleges to set up a &quot;Walk for Mankind,&quot; and encouraged students, adults, company executives to donate. Bertier occasionally met with others who suffered similar injuries, helping them with their rehabilitation. Outside of his hometown, Gerry made speeches across the country for rights for the handicapped. He addressed subjects such as making buildings handicapped accessible. Bertier gained employment with Abbey Medical, selling medical equipment to the handicapped. His position allowed him to attend wheelchair sporting events all over the country.
Some Chevys and some old race cars
Old 11-25-2010, 04:07 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 427TJ</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body"> The recall was due to the fact that the driver's side motor mount could break under certain &quot;abusive&quot; conditions, causing the engine to lift on the driver's side, thereby causing the mechanical throttle to be pulled to full WOT condition without the ability to release itself, since it was now at full throttle, causing more of a high-horsepower, torque-over condition, pinning the carb at WOT till the engine blew up, the car crashed, or the driver was intelligent enough to turn the ignition key off, diffusing the impending explosion. </div></div>
I was intelligent enough to shove my foot under the gas pedal and unstick the WOT! (High school, 1979, driving my buddy's stock L35/M40 '67 SS396 Camaro. That's how we learned the engine mounts were broken.) </div></div>
You must have had one strong foot to pull that motor back down!
[img]<<GRAEMLIN_URL>>/grin.gif[/img]
